TNG not logging calls
Postby stephen » Mon Apr 02, 2012 9:54 am
Hi
We're in the process of replacing our old Asterisk 1.4 server to new hardware on Asterisk 1.8.
When I look in asterisk I can see TNG connects fine on the manager interface, but when I make calls, its not logging any calls. I managed to find a log in TNG that gives me this message:
2012-04-01 12:30:35:027 [1.0.7.0] - AMI Exception:Event: Dial[10]Privilege: call,all[10]SubEvent: End[10]Channel: SIP/153-00000000[10]UniqueID: 1333276396.0[10]DialStatus: ANSWER[10]
2012-04-01 12:30:35:026 [1.0.7.0] - AMI Exception:ProcessAMIEvent: Access violation at address 0813F4D5, accessing address 000000A9
2012-04-01 12:30:00:884 [1.0.7.0] - AMI connected to port 5038 on 10.0.8.201
2012-04-01 12:30:00:759 [1.0.7.0] - AMI Exception:ConnectToAsterisk: Socket Error # 111[13][10]Connection refused.
2012-04-01 12:30:00:634 [1.0.7.0] - AMI Exception:Connection Closed Gracefully.
2012-04-01 12:30:00:634 [1.0.7.0] - AMI Disconnected:0 -
2012-04-01 12:27:04:551 [1.0.7.0] - AMI Exception:Event: Dial[10]Privilege: call,all[10]SubEvent: End[10]Channel: SIP/153-00000000[10]UniqueID: 1333276186.0[10]DialStatus: ANSWER[10]
2012-04-01 12:27:04:551 [1.0.7.0] - AMI Exception:ProcessAMIEvent: Access violation at address 0813F4D5, accessing address 000000A9
2012-04-01 12:23:44:337 [1.0.7.0] - AMI connected to port 5038 on 10.0.8.201
2012-04-01 12:23:44:212 [1.0.7.0] - AMI Exception:ConnectToAsterisk: Socket Error # 111[13][10]Connection refused.
2012-04-01 12:23:44:087 [1.0.7.0] - AMI Exception:Connection Closed Gracefully.
So it looks like TNG is in fact picking up the calls being made, but I'm not sure why its not logging it. Perhaps because of access violation part?
stephen
Re: TNG not logging calls
Postby Belinda Frick » Mon Apr 02, 2012 2:08 pm
Postby stephen » Fri Apr 06, 2012 11:16 am
Hi. I'm still getting these messages:
2012-04-06 11:06:18:547 [1.0.7.7] - AMI Exception:ProcessAMIEvent: ProcessDial 3: Access violation at address 08142D16, accessing address 000000A9
2012-04-06 11:06:18:547 [1.0.7.7] - AMI Exception:Event: Dial[10]Privilege: call,all[10]SubEvent: End[10]Channel: SIP/5747-00000004[10]UniqueID: 1333703343.4[10]DialStatus: ANSWER[10]
2012-04-06 11:08:23:759 [1.0.7.7] - AMI Exception:ProcessAMIEvent: ProcessDial 3: Access violation at address 08142D16, accessing address 000000A9
2012-04-06 11:08:23:759 [1.0.7.7] - AMI Exception:Event: Dial[10]Privilege: call,all[10]SubEvent: End[10]Channel: SIP/192.169.5.5-0000000a[10]UniqueID: 1333703456.10[10]DialStatus: ANSWER[10]
2012-04-06 11:09:07:739 [1.0.7.7] - AMI Exception:ProcessAMIEvent: ProcessDial 3: Access violation at address 08142D16, accessing address 000000A9
2012-04-06 11:09:07:739 [1.0.7.7] - AMI Exception:Event: Dial[10]Privilege: call,all[10]SubEvent: End[10]Channel: SIP/5747-00000008[10]UniqueID: 1333703396.8[10]DialStatus: ANSWER[10]
2012-04-06 11:09:16:325 [1.0.7.7] - AMI Exception:ProcessAMIEvent: ProcessDial 3: Access violation at address 08142D16, accessing address 000000A9
2012-04-06 11:09:16:325 [1.0.7.7] - AMI Exception:Event: Dial[10]Privilege: call,all[10]SubEvent: End[10]Channel: SIP/192.169.5.5-00000006[10]UniqueID: 1333703382.6[10]DialStatus: ANSWER[10]
I have followed each thread from AMI Exception:ProcessAMIEvent: Access violation Asterisk 1.8
and also made sure I have my configration set as described in: viewtopic.php?f=24&t=2637#p2659
The ami.txt log does not show any errors when I make calls (at least, I don't see any), only the tng log. I would really like to get this sorted.
stephen
Postby stephen » Tue Apr 10, 2012 9:22 am
This is what I see when I don't have TNG running as a daemon and making a call:
TimeStamp: 09:21:59.912
Event: Newchannel
Privilege: call,all
Channel: SIP/5776-00000006
ChannelState: 0
ChannelStateDesc: Down
CallerIDNum: 5776
CallerIDName: 5776
AccountCode:
Exten: 0792393159
Context: default
Uniqueid: 1334042526.6
TimeStamp: 09:21:59.917
Event: Newstate
Privilege: call,all
ChannelState: 4
ChannelStateDesc: Ring
CallerIDNum: 5776
CallerIDName: 5776
ConnectedLineNum:
ConnectedLineName:
TimeStamp: 09:21:59.921
Event: Newchannel
Privilege: call,all
Channel: SIP/trunk_mweb-00000007
ChannelState: 0
CallerIDNum:
CallerIDName:
AccountCode:
Exten:
Context: default
Uniqueid: 1334042526.7
TimeStamp: 09:21:59.924
Event: NewCallerid
Privilege: call,all
CallerIDNum: 0792393159
CallerIDName:
CID-CallingPres: 0 (Presentation Allowed, Not Screened)
TimeStamp: 09:21:59.926
Event: Dial
Privilege: call,all
SubEvent: Begin
Destination: SIP/trunk_mweb-00000007
CallerIDNum: 5776
CallerIDName: 5776
ConnectedLineNum: <unknown>
ConnectedLineName: <unknown>
UniqueID: 1334042526.6
DestUniqueID: 1334042526.7
Dialstring: trunk_mweb/0792393159
TimeStamp: 09:22:04.914
Event: Newstate
Privilege: call,all
ChannelState: 5
ChannelStateDesc: Ringing
CallerIDName:
ConnectedLineNum: 5776
ConnectedLineName: 5776
TimeStamp: 09:22:08.072
Event: Registry
Privilege: system,all
ChannelType: SIP
Domain: sip.mweb.net
Status: Registered
TimeStamp: 09:22:08.396
Event: Newstate
Privilege: call,all
ChannelState: 6
ChannelStateDesc: Up
CallerIDName:
TimeStamp: 09:22:08.403
Event: Newstate
Privilege: call,all
ChannelState: 6
CallerIDNum: 5776
CallerIDName: 5776
ConnectedLineNum:
ConnectedLineName:
TimeStamp: 09:22:08.407
Event: NewAccountCode
Privilege: call,all
AccountCode:
OldAccountCode:
TimeStamp: 09:22:08.409
Event: Bridge
Privilege: call,all
Bridgestate: Link
Bridgetype: core
Channel1: SIP/5776-00000006
Channel2: SIP/trunk_mweb-00000007
Uniqueid1: 1334042526.6
Uniqueid2: 1334042526.7
CallerID1: 5776
CallerID2: 0792393159
TimeStamp: 09:22:11.249
Event: Unlink
Privilege: call,all
CallerID1: 5776
TimeStamp: 09:22:11.254
Event: Hangup
Privilege: call,all
CallerIDName: <unknown>
Cause: 16
Cause-txt: Normal Clearing
TimeStamp: 09:22:11.259
Event: Dial
Privilege: call,all
SubEvent: End
DialStatus: ANSWER
TimeStamp: 09:22:11.263
Event: Hangup
Privilege: call,all
CallerIDNum: 5776
CallerIDName: 5776
Cause: 16
TimeStamp: 09:22:23.638
Event: PeerStatus
ChannelType: SIP
Peer: SIP/5776
PeerStatus: Registered
Address: 10.0.8.21:5060
TimeStamp: 09:22:24.249
Event: Registry
ChannelType: SIP
Status: Registered
It does not look like errors or permission problems.
stephen
Postby stephen » Tue Apr 10, 2012 2:29 pm
My Asterisk configs as follow:
manager.conf
[loftsasterisk]
secret=xxxxxx
deny=0.0.0.0/0.0.0.0
permit=127.0.0.1/255.255.255.255
permit=10.0.8.203/255.255.255.255
permit=10.0.15.249/255.255.255.255
permit=10.0.8.210/255.255.255.255
read=system,call,log,verbose,command,agent,user
write=system,call,log,verbose,command,agent,user
writetimeout=10000
cdr_custom.conf
[mappings]
Master.csv => "${CDR(clid)}","${CDR(src)}","${CDR(dst)}","${CDR(dcontext)}","${CDR(channel)}","${CDR(dstchannel)}","${CDR(lastapp)}","${CDR(lastdata)}","${CDR(start)}","${CDR(answer)}","${CDR(end)}","${CDR(duration)}","${CDR(billsec)}","${CDR(disposition)}","${CDR(amaflags)}","${CDR(accountcode)}","${CDR(uniqueid)}","${CDR(userfield)}"
Asterisk log:
tail /var/log/asterisk/cdr-custom/Master.csv -n1
""5776" <5776>","5776","0792393159","default","SIP/5776-00000006","SIP/trunk_mweb-00000007","Dial","SIP/trunk_mweb/0792393159","2012-04-10 14:01:10","2012-04-10 14:01:17","2012-04-10 14:01:20","10","3","ANSWERED","DOCUMENTATION","","1334059270.6",""
What other info can I supply to get some real help ?
stephen
Postby stephen » Thu Apr 12, 2012 7:41 am
Hi
I installed TNG on the Asterisk server as Odette suggested, as per our conversation the other day and it seems to log now. We are fine with running TNG on the same server and happy that its working.
Only thing wrong now, when I sent the registration file, I got a response back saying that the company email already exists. I'm sure that is an automated response. Should I sent the registration file again? If yes, to which address?
stephen
Postby Odette Danster » Thu Apr 12, 2012 9:10 am
Dear Stephen
Please log into TNG, under General Settings - Company Details, change the current company e-mail address to another valid e-mail account and save the settings.
Once company e-mail address has been changed, please navigate to the License page and re-create the registration file and send the new registration file to register@datatex.co.za
Yours Sincerely
Odette
Odette Danster
