BP Barring with TNG
BP Barring with TNG
Postby Squash » Fri Apr 20, 2012 2:12 pm
Problem with TNG barring users on a BP 250 using virtual exts. Baring and unbarring from TNG using budgeting only takes place when the services are reset. Need urgent assistance please.
Squash
Re: BP Barring with TNG
Postby Odette Danster » Mon Apr 30, 2012 9:48 am
Dear Colin
We've investigated the logs you sent and found entries indicating that BMS system was still starting up and not connected correctly at the time the barring service tried to connect to it.
Please log into BMS manually and take note of the time it takes to load, it must show "online ready" under the system status. Please use link below for more detailed information.
viewtopic.php?f=24&t=107&start=0
Kind Regards
Odette
Odette Danster
