TNG Software not Logging from the Buffer
Postby culrich » Wed May 16, 2012 9:27 am
Hi
I am having serious problems with a TNG Buffer Unit.
I have installed it to a Physical machine and it started working fine, after about 3 to 4 days it stops logging from the buffer to the Software.
I have to restart the service and sometimes restart the server 3 or 4 times and only the following day does the software log again.
Regards
Carl
culrich
Re: TNG Software not Logging from the Buffer
Postby Belinda Frick » Wed May 16, 2012 2:12 pm
For buffer not detected issues, please refer to forum post: My TNG buffer is not being detected
Note TNG has the feature to alert you if no calls has been received for a configured period within your office hours, please refer to forum post: TNG Alarm Configuration (TNG v1.0.6.5 or newer)
Postby culrich » Thu May 17, 2012 8:17 am
Thanks very much Belinda
Unfortunatley thats the weird thing. It does not say that the buffer is a problem.
The software looks like it is working but no calls are showing for the current date, only the date in the picture.
Even reports show no new calls.
Regards
Carl
culrich
Postby Leon van Heerden » Mon May 21, 2012 9:44 am
Hi,
Which PBX model are you connecting too?
Are you using a Serial connection to the PBX or a network connection?
Are there any errors in the TNG logs?
Postby culrich » Mon May 21, 2012 12:28 pm
Thanks Leon
The PBX is a Mitel 3300
Connection is via the network and I have asked the PBX installer to configure it to send results, which it does for a while and then stops.
I have attached a screenshot of the logs, the dates look very odd.
I have also attached some logs the last date that it looked like it connected was 03/05/2012
I have installed another one of these units in their JHB branch and its working perectly, its just this one.
Thanks
Carl
culrich
Postby Leon van Heerden » Mon May 21, 2012 4:36 pm
I see no Raw.txt files, that means that "Log Rawdata" option is not enabled in the Settings of TNG.
You can enable it under the Communications Configuration. This will allow future rawdata to be captured.
There is also a new feature in TNG 1.1.1.8 that allows it to try and re-connect to Network PBXs if the connection is not supplying information for more than an hour.
We are preparing the update for normal release, but I have added a Link for you.
Please make sure your TNG subscription is up to date before you try this, as updates are only allowed if the subscription is up to date.
Postby culrich » Tue May 22, 2012 1:49 pm
Thanks Leon
Looks like it is logging again, the Rawdata worked.
i'll monitor it for a while.
Thanks
Carl
culrich
Postby Belinda Frick » Wed May 23, 2012 3:59 pm
Dear Charl
For things to keep in mind with TNG and the Mitel PABX,
please see post: TNG and Mitel PABX
Regards
Belinda
