Incorrect time on TNG program.
Postby juan.mostert » Thu May 31, 2012 12:10 pm
Hi team
I have a issue with a SL1000 where the call list time is incorrect on the TNG but correct on the raw data. Please advise me on this. Also after assigning the new plugin PNEC_96i_Rev2.dll i am not receiving any data from the system. I tried setting it back to the initial plugin but still nothing is working. Please advise.
01 PTRS  11:26 31/05 001  00:05:48 205                         0:09
02 POT   11:32 31/05 002  00:00:14 206        0215087200             0
03 POT   11:33 31/05 001  00:01:23 206        0826946606             0
04 POT   11:35 31/05 001  00:00:27 206        0215550855             0
05 POT   11:39 31/05 001  00:00:13 203        0726327596             0
06 PIN   11:40 31/05 002  00:00:22 210                         0:14
07 POT   11:41 31/05 001  00:00:08 203        101999                 0
08 PIN   11:41 31/05 005  00:01:19 209                         0:10
09 POT   11:43 31/05 001  00:00:07 203        101999                 0
10 PIN   11:40 31/05 006  00:03:04 210                         0:12
11 POT   11:44 31/05 001  00:01:47 210        0215118004             0
12 POT   11:46 31/05 001  00:02:48 210        0218422762             0
13 PIN   11:50 31/05 002  00:00:21 200                         0:03
14 PTRS  11:51 31/05 002  00:00:40 206                         0:03
15 PIN   11:51 31/05 006  00:00:24 200                         0:02
16 PTRS  11:51 31/05 006  00:02:50 210                         0:02
17 PIN   11:56 31/05 001  00:00:17 200                         0:04
18 PTRS  11:57 31/05 001  00:01:01 206                         0:04
19 POT   11:58 31/05 002  00:00:14 210        0215118004             0
20 PIN   11:57 31/05 005  00:00:46 200                         0:02
juan.mostert
Re: Incorrect time on TNG program.
Postby Belinda Frick » Tue Jun 05, 2012 4:21 pm
The output format in your post is not that of the SL1000, refer to forum post for example of rawdata/output file: PABX3 PLUGIN: NEC 96i Revision 2
You need to use the 'PNEC_Aspire_v6r0.dll'. See example below with rawdata file you provided and output of plugin(note the date and times matches):
For NEC Aspire version 6 release 0, see forum post: Which plugin do I use for the Philips IPC 500?
