New plugin for MG100/300 pabx
Postby David » Fri Jun 15, 2012 11:25 am
RS232-form-of-ipecsmg.rar
Please can you make a new plugin on the TNG for the LG-MG100/300 pabx
David
Re: New plugin for MG100/300 pabx
Postby Belinda Frick » Fri Jun 15, 2012 11:37 am
To write a plugin or to see if we already have a plugin that will translate the call details the PABX sends off, we need the actual rawdata file. You can capture the rawdata using PABX3 (in the Tools folder on the TNG install CD) or for example putty - see forum post How do I enable logging of data in Putty?.
If you use PABX3 from the TNG install CD, simply copy it into your Datatex folder. Double-click to run the pabx3.exe in the PABX3 folder. Check under 'TOOLS' that there is a tick next to create rawdata - refer to forum post Why is my rawdata not logging to file? Configure PABX3 to connect to the PABX.
If you cannot capture the data with suggested methods then your PABX does not send if off as per TNG call logging methods which is:
1.) serial connection
2.) network (connect to TCP IP and port)
3.) input file
Your rawdata needs to be accessible via these methods. Please forward me a raw data file.
Postby Belinda Frick » Thu Jun 21, 2012 3:10 pm
LG MG100 rawdata example:
LG-MG_smdr out put.rar
Postby Belinda Frick » Thu Jun 21, 2012 4:47 pm
The file with rawdata is shifted. I also disabled WORD WRAP, but it still does not look right.
Please check and send me the correct data (unformatted, as received from the PABX unit).
Postby Belinda Frick » Tue Jun 26, 2012 10:09 am
If you can format your output to that of the LG LDK300 IP,
you can use the plugin attached in the forum post:
Which plugin do I use for the LG LDK300 IP?
NOTE: The plugin caters for both output examples displayed in the forum post.
Postby Leon van Heerden » Mon Jul 09, 2012 5:59 pm
Hi,
I have updated this post with the new plugin. Can you please verify that it is working properly for your PBX.
