Importing extensions from extension.txt
Postby annam » Wed Oct 31, 2012 11:16 am
When I import from extension.txt within TNG, will this option update the extension file in the DEBSWANA Folder?
annam
Re: Importing extensions from extension.txt
Postby Belinda Frick » Thu Nov 01, 2012 10:22 am
If you update the extensions for the TNG that works with the Debswana interface it will update the extensions to it.
