Samsung 7030 No Call Detail
Postby hendrik » Wed Nov 21, 2012 1:14 pm
2012-11-21 12:13:33:671 [1.0.7.6] - Memory Status Object Created
2012-11-21 12:13:33:718 [1.0.7.6] - Available Memory: NPR = 464 ATT = 429841613 TOT = 2137174016 MCC = 926383
2012-11-21 12:13:34:015 [1.0.7.6] - Last File Saved: 1data_1.0.0.0
2012-11-21 12:13:34:031 [1.0.7.6] - Last File Saved Checksum:
2012-11-21 12:13:34:031 [1.0.7.6] - Loading: C:\Program Files\datatex\tng\data\1data_1.0.7.6.dat
2012-11-21 12:13:34:031 [1.0.7.6] - Loading: Assigned File -- OK
2012-11-21 12:13:34:031 [1.0.7.6] - Loading: Open File -- Failed.  Creating new file.
2012-11-21 12:13:34:031 [1.0.7.6] - Loaddata completed: TNGCalldata Count = 1
2012-11-21 12:13:34:031 [1.0.7.6] - Reserving Unused Memory
2012-11-21 12:13:34:609 [1.0.7.6] - Reading Settings
2012-11-21 12:13:34:609 [1.0.7.6] - Settings Read
2012-11-21 12:13:34:625 [1.0.7.6] - TermChar    : [10]
2012-11-21 12:13:34:625 [1.0.7.6] - Com         : COM1
2012-11-21 12:13:34:625 [1.0.7.6] - BaudRate    : 9600
2012-11-21 12:13:34:625 [1.0.7.6] - Bits        : 8
2012-11-21 12:13:34:625 [1.0.7.6] - Parity      : N
2012-11-21 12:13:34:625 [1.0.7.6] - Stop        : 1
2012-11-21 12:13:34:625 [1.0.7.6] - SoftFlow    : 0
2012-11-21 12:13:34:625 [1.0.7.6] - HardFlow    : 0
2012-11-21 12:13:34:625 [1.0.7.6] - COM1 Ready
2012-11-21 12:13:34:625 [1.0.7.6] - SerialThread : 1076
2012-11-21 12:13:34:640 [1.0.7.6] - Integration: Server Created
2012-11-21 12:13:34:640 [1.0.7.6] - Integration Object Created
2012-11-21 12:13:34:640 [1.0.7.6] - Barring: Server Created
2012-11-21 12:13:34:640 [1.0.7.6] - Barring Object Created
2012-11-21 12:13:34:640 [1.0.7.6] - CAM: Created: Trunk Alarm: 0 minutes. Total Alarm: 0 minutes.
2012-11-21 12:13:34:640 [1.0.7.6] - Plugin:  Reading Settings.
2012-11-21 12:13:34:640 [1.0.7.6] - RAW Data logging enabled to 2012-11-22 13:13
2012-11-21 12:13:34:640 [1.0.7.6] - Plugin: Loading Rules..
2012-11-21 12:13:34:656 [1.0.7.6] - Plugin: Loading Rules.. Completed.
2012-11-21 12:13:34:656 [1.0.7.6] - Loading Plugin: C:\Program Files\datatex\tng\plugins\PSamsung_7400.dll
2012-11-21 12:13:34:734 [1.0.7.6] - PSamsung_7400, v2008.11.10.1 loaded successfully
2012-11-21 12:13:34:734 [1.0.7.6] - Loading Scheduled Reports..
2012-11-21 12:13:34:734 [1.0.7.6] - Loading Scheduled Reports.. Completed.
2012-11-21 12:13:34:734 [1.0.7.6] - User tngreportschedule connected from 127.0.0.1
2012-11-21 12:13:34:734 [1.0.7.6] -  [FRP] Clearing File List.
2012-11-21 12:13:34:734 [1.0.7.6] - Verifying Buffer...
2012-11-21 12:13:34:750 [1.0.7.6] - Startup for ***[C:\Program Files\datatex\tng\tng.exe --Normal-- ]*** OK
2012-11-21 12:13:35:250 [1.0.7.6] - Barring: Server [20009]: Started OK
2012-11-21 12:13:35:250 [1.0.7.6] - Integration: Server [20003]: Started OK
2012-11-21 12:14:03:890 [1.0.7.6] - No Response on port:COM1
2012-11-21 12:14:03:890 [1.0.7.6] - No valid buffer on selected port.  Searching for buffer...
2012-11-21 12:14:03:906 [1.0.7.6] - The following ports will be searched [COM1, COM2, COM3, COM4]
2012-11-21 12:14:03:906 [1.0.7.6] - Attempt 1 to find buffer
2012-11-21 12:14:03:906 [1.0.7.6] - Found Port : COM1 [Attempt:1]
2012-11-21 12:14:03:906 [1.0.7.6] - Found Port : Opened COM1 [Attempt:1]
2012-11-21 12:14:09:937 [1.0.7.6] - No Response on port:COM1 [Attempt:1]
2012-11-21 12:14:09:953 [1.0.7.6] - Found Port : COM2 [Attempt:1]
2012-11-21 12:14:09:953 [1.0.7.6] - Found Port : Opened COM2 [Attempt:1]
2012-11-21 12:14:15:984 [1.0.7.6] - No Response on port:COM2 [Attempt:1]
2012-11-21 12:14:16:000 [1.0.7.6] - Found Port : COM3 [Attempt:1]
2012-11-21 12:14:16:000 [1.0.7.6] - Found Port : Opened COM3 [Attempt:1]
2012-11-21 12:14:22:031 [1.0.7.6] - No Response on port:COM3 [Attempt:1]
2012-11-21 12:14:22:031 [1.0.7.6] - Found Port : COM4 [Attempt:1]
2012-11-21 12:14:22:031 [1.0.7.6] - Found Port : Opened COM4 [Attempt:1]
2012-11-21 12:14:28:062 [1.0.7.6] - No Response on port:COM4 [Attempt:1]
2012-11-21 12:14:28:062 [1.0.7.6] - Attempt 2 to find buffer
2012-11-21 12:14:28:062 [1.0.7.6] - Found Port : COM1 [Attempt:2]
2012-11-21 12:14:28:062 [1.0.7.6] - Found Port : Opened COM1 [Attempt:2]
2012-11-21 12:15:03:218 [1.0.7.6] - No Response on port:COM1 [Attempt:2]
2012-11-21 12:15:03:234 [1.0.7.6] - Found Port : COM2 [Attempt:2]
2012-11-21 12:15:03:234 [1.0.7.6] - Found Port : Opened COM2 [Attempt:2]
2012-11-21 12:15:38:390 [1.0.7.6] - No Response on port:COM2 [Attempt:2]
2012-11-21 12:15:38:406 [1.0.7.6] - Found Port : COM3 [Attempt:2]
2012-11-21 12:15:38:406 [1.0.7.6] - Found Port : Opened COM3 [Attempt:2]
2012-11-21 12:16:13:562 [1.0.7.6] - No Response on port:COM3 [Attempt:2]
2012-11-21 12:16:13:562 [1.0.7.6] - Found Port : COM4 [Attempt:2]
2012-11-21 12:16:13:562 [1.0.7.6] - Found Port : Opened COM4 [Attempt:2]
2012-11-21 12:16:48:718 [1.0.7.6] - No Response on port:COM4 [Attempt:2]
2012-11-21 12:16:48:718 [1.0.7.6] - Attempt 3 to find buffer
2012-11-21 12:16:48:718 [1.0.7.6] - Found Port : COM1 [Attempt:3]
2012-11-21 12:16:48:718 [1.0.7.6] - Found Port : Opened COM1 [Attempt:3]
2012-11-21 12:17:46:968 [1.0.7.6] - No Response on port:COM1 [Attempt:3]
2012-11-21 12:17:46:984 [1.0.7.6] - Found Port : COM2 [Attempt:3]
2012-11-21 12:17:46:984 [1.0.7.6] - Found Port : Opened COM2 [Attempt:3]
2012-11-21 12:17:57:625 [1.0.7.6] - User tngreportschedule disconnected
2012-11-21 12:17:57:875 [1.0.7.6] - Import Thread : Shutting Down..
2012-11-21 12:17:57:953 [1.0.7.6] -  [FRP] Clearing File List.
2012-11-21 12:17:58:296 [1.0.7.6] - Import Thread: Shutting Down.. Completed
2012-11-21 12:17:58:296 [1.0.7.6] - Reports Schedule Thread : Shutting Down..
2012-11-21 12:17:59:734 [1.0.7.6] - Reports Schedule Thread: Shutting Down.. Completed
2012-11-21 12:17:59:734 [1.0.7.6] - SerialThread: Shutting Down..
2012-11-21 12:20:03:015 [1.0.7.6] - Memory Status Object Created
2012-11-21 12:20:03:250 [1.0.7.6] - Available Memory: NPR = 464 ATT = 449363558 TOT = 2137174016 MCC = 968456
2012-11-21 12:20:19:406 [1.0.7.6] - Last File Saved: 2data_1.0.7.6
2012-11-21 12:20:19:406 [1.0.7.6] - Last File Saved Checksum: Check:[2DA58CB8AC656846783D3FEE41195338]
2012-11-21 12:20:19:515 [1.0.7.6] - Loading: C:\Program Files\datatex\tng\data\2data_1.0.7.6.dat
2012-11-21 12:20:19:515 [1.0.7.6] - Loading: Assigned File -- OK
2012-11-21 12:20:19:562 [1.0.7.6] - Loading: Opened File -- OK
2012-11-21 12:20:19:562 [1.0.7.6] - Loading: 1 Record(s) Loaded -- OK -- Check:[2DA58CB8AC656846783D3FEE41195338]
2012-11-21 12:20:19:562 [1.0.7.6] - Loaddata completed: TNGCalldata Count = 1
2012-11-21 12:20:19:562 [1.0.7.6] - Reserving Unused Memory
2012-11-21 12:20:20:031 [1.0.7.6] - Reading Settings
2012-11-21 12:20:20:468 [1.0.7.6] - Settings Read
2012-11-21 12:20:20:515 [1.0.7.6] - TermChar    : [10]
2012-11-21 12:20:20:515 [1.0.7.6] - Com         : COM1
2012-11-21 12:20:20:515 [1.0.7.6] - BaudRate    : 9600
2012-11-21 12:20:20:515 [1.0.7.6] - Bits        : 8
2012-11-21 12:20:20:515 [1.0.7.6] - Parity      : N
2012-11-21 12:20:20:515 [1.0.7.6] - Stop        : 1
2012-11-21 12:20:20:515 [1.0.7.6] - SoftFlow    : 0
2012-11-21 12:20:20:515 [1.0.7.6] - HardFlow    : 0
2012-11-21 12:20:20:515 [1.0.7.6] - COM1 Ready
2012-11-21 12:20:20:515 [1.0.7.6] - SerialThread : 3648
2012-11-21 12:20:20:515 [1.0.7.6] - Integration: Server Created
2012-11-21 12:20:20:515 [1.0.7.6] - Integration Object Created
2012-11-21 12:20:20:531 [1.0.7.6] - Barring: Server Created
2012-11-21 12:20:20:531 [1.0.7.6] - Barring Object Created
2012-11-21 12:20:20:531 [1.0.7.6] - CAM: Created: Trunk Alarm: 0 minutes. Total Alarm: 0 minutes.
2012-11-21 12:20:20:531 [1.0.7.6] - Plugin:  Reading Settings.
2012-11-21 12:20:20:531 [1.0.7.6] - RAW Data logging enabled to 2012-11-22 13:13
2012-11-21 12:20:20:531 [1.0.7.6] - Plugin: Loading Rules..
2012-11-21 12:20:20:625 [1.0.7.6] - Plugin: Loading Rules.. Completed.
2012-11-21 12:20:20:765 [1.0.7.6] - Loading Plugin: C:\Program Files\datatex\tng\plugins\PSamsung_7400.dll
2012-11-21 12:20:21:296 [1.0.7.6] - PSamsung_7400, v2008.11.10.1 loaded successfully
2012-11-21 12:20:21:296 [1.0.7.6] - Loading Scheduled Reports..
2012-11-21 12:20:21:296 [1.0.7.6] - Loading Scheduled Reports.. Completed.
2012-11-21 12:20:21:312 [1.0.7.6] - User tngreportschedule connected from 127.0.0.1
2012-11-21 12:20:21:328 [1.0.7.6] -  [FRP] Clearing File List.
2012-11-21 12:20:21:343 [1.0.7.6] - Verifying Buffer...
2012-11-21 12:20:22:296 [1.0.7.6] - Barring: Server [20009]: Started OK
2012-11-21 12:20:22:296 [1.0.7.6] - Integration: Server [20003]: Started OK
2012-11-21 12:20:22:296 [1.0.7.6] - Startup for ***[C:\Program Files\datatex\tng\tng.exe --Normal-- ]*** OK
2012-11-21 12:20:50:562 [1.0.7.6] - No Response on port:COM1
2012-11-21 12:20:50:562 [1.0.7.6] - No valid buffer on selected port.  Searching for buffer...
2012-11-21 12:20:50:578 [1.0.7.6] - The following ports will be searched [COM1, COM2, COM3, COM4, COM5]
2012-11-21 12:20:50:578 [1.0.7.6] - Attempt 1 to find buffer
2012-11-21 12:20:50:578 [1.0.7.6] - Found Port : COM1 [Attempt:1]
2012-11-21 12:20:50:578 [1.0.7.6] - Found Port : Opened COM1 [Attempt:1]
2012-11-21 12:20:56:609 [1.0.7.6] - No Response on port:COM1 [Attempt:1]
2012-11-21 12:20:56:625 [1.0.7.6] - Found Port : COM2 [Attempt:1]
2012-11-21 12:20:56:625 [1.0.7.6] - Found Port : Opened COM2 [Attempt:1]
2012-11-21 12:21:02:656 [1.0.7.6] - No Response on port:COM2 [Attempt:1]
2012-11-21 12:21:02:671 [1.0.7.6] - Found Port : COM3 [Attempt:1]
2012-11-21 12:21:02:671 [1.0.7.6] - Found Port : Opened COM3 [Attempt:1]
2012-11-21 12:21:08:703 [1.0.7.6] - No Response on port:COM3 [Attempt:1]
2012-11-21 12:21:08:703 [1.0.7.6] - Found Port : COM4 [Attempt:1]
2012-11-21 12:21:08:703 [1.0.7.6] - Found Port : Opened COM4 [Attempt:1]
2012-11-21 12:21:14:734 [1.0.7.6] - No Response on port:COM4 [Attempt:1]
2012-11-21 12:21:14:734 [1.0.7.6] - Found Port : COM5 [Attempt:1]
2012-11-21 12:21:14:812 [1.0.7.6] - Found Port : Opened COM5 [Attempt:1]
2012-11-21 12:21:20:906 [1.0.7.6] - Comport Responded, checking for TNG Buffer...
2012-11-21 12:21:26:078 [1.0.7.6] - Buffer found on Port:COM5
2012-11-21 12:21:26:156 [1.0.7.6] - Port COM5 opened
2012-11-21 12:21:26:156 [1.0.7.6] - Valid Buffer Found.
2012-11-21 12:21:31:265 [1.0.7.6] - First start after installation checks
2012-11-21 12:21:41:265 [1.0.7.6] - Reading Settings
2012-11-21 12:21:41:390 [1.0.7.6] - Settings Read
2012-11-21 12:21:41:500 [1.0.7.6] - TermChar    : [10]
2012-11-21 12:21:41:500 [1.0.7.6] - Com         : COM5
2012-11-21 12:21:41:500 [1.0.7.6] - BaudRate    : 9600
2012-11-21 12:21:41:500 [1.0.7.6] - Bits        : 8
2012-11-21 12:21:41:500 [1.0.7.6] - Parity      : N
2012-11-21 12:21:41:500 [1.0.7.6] - Stop        : 1
2012-11-21 12:21:41:500 [1.0.7.6] - SoftFlow    : 0
2012-11-21 12:21:41:500 [1.0.7.6] - HardFlow    : 0
2012-11-21 12:21:41:500 [1.0.7.6] - COM5 Ready
2012-11-21 12:22:02:656 [1.0.7.6] - ConnectToNetworkPABX: Host[10.0.14.99] Port[5100]Socket Error # 10060[13][10]Connection timed out.
2012-11-21 12:22:02:656 [1.0.7.6] - First start after installation checks end.
2012-11-21 12:22:02:656 [1.0.7.6] - Exchange Library      : Verifying Versions...
2012-11-21 12:22:02:656 [1.0.7.6] - Error with MD5 : Cannot open file "C:\Program Files\datatex\tng\exchange.dat". The system cannot find the file specified
2012-11-21 12:22:02:656 [1.0.7.6] - Exchange Library      : exchange.dat Changed!!
2012-11-21 12:22:03:296 [1.0.7.6] - Exchange Library      : DLL has Changed!!
2012-11-21 12:22:03:312 [1.0.7.6] - Exchange Library      : Recreating Library [ver 2009.08.01.01] for source number 27117440278
2012-11-21 12:23:05:671 [1.0.7.6] - Exchange Library      : Recreating Completed (22464 codes)!
2012-11-21 12:23:05:875 [1.0.7.6] - 22388 exchange entries loaded.
2012-11-21 12:23:25:578 [1.0.7.6] - User admin connected from 10.0.14.13
2012-11-21 12:25:06:250 [1.0.7.6] - Synchronizing Extensions, PIN Users, Accounts, Trunks, Phonebook from 2012-11-20 00:00 to 2012-11-20 23:59
2012-11-21 12:25:06:250 [1.0.7.6] - 0 Data records synchronized
2012-11-21 12:26:04:765 [1.0.7.6] - Reading Settings
2012-11-21 12:26:04:906 [1.0.7.6] - ConnectToNetworkPABX: Host[10.0.14.99] Port[5100]Socket Error # 10038[13][10]Socket operation on non-socket.
2012-11-21 12:26:04:906 [1.0.7.6] - Settings Read
2012-11-21 12:26:05:015 [1.0.7.6] - TermChar    : [10]
2012-11-21 12:26:05:015 [1.0.7.6] - Com         : COM5
2012-11-21 12:26:05:015 [1.0.7.6] - BaudRate    : 9600
2012-11-21 12:26:05:015 [1.0.7.6] - Bits        : 8
2012-11-21 12:26:05:015 [1.0.7.6] - Parity      : N
2012-11-21 12:26:05:015 [1.0.7.6] - Stop        : 1
2012-11-21 12:26:05:015 [1.0.7.6] - SoftFlow    : 0
2012-11-21 12:26:05:015 [1.0.7.6] - HardFlow    : 0
2012-11-21 12:26:05:015 [1.0.7.6] - COM5 Ready
2012-11-21 12:26:05:031 [1.0.7.6] - ConnectToNetworkPABX: Host[10.0.14.99] Port[5100]Already connected.
2012-11-21 12:26:05:031 [1.0.7.6] - ConnectToNetworkPABX: Host[10.0.14.99] Port[5100]Socket Error # 10038[13][10]Socket operation on non-socket.
2012-11-21 12:26:05:156 [1.0.7.6] - ConnectToNetworkPABX: Host[10.0.14.99] Port[5100]Already connected.
2012-11-21 12:26:05:156 [1.0.7.6] - ConnectToNetworkPABX: Host[10.0.14.99] Port[5100]Socket Error # 10038[13][10]Socket operation on non-socket.
2012-11-21 12:26:05:156 [1.0.7.6] - Raw Data Logging Enabled to 2012-11-21 13:26
2012-11-21 12:26:05:171 [1.0.7.6] - Import Raw Data Disabled
2012-11-21 12:26:05:171 [1.0.7.6] - ApplyGeneralSettings: OK - Tech Saving=True!
2012-11-21 12:26:26:390 [1.0.7.6] - ConnectToNetworkPABX: Host[10.0.14.99] Port[5100]Socket Error # 10060[13][10]Connection timed out.
2012-11-21 12:29:01:437 [1.0.7.6] - ConnectToNetworkPABX: Host[10.0.14.99] Port[5100]Socket Error # 10053[13][10]Software caused connection abort.
2012-11-21 12:29:01:578 [1.0.7.6] - TCPClient Connected to Network PBX 10.0.14.99:5100
2012-11-21 12:29:33:578 [1.0.7.6] - Disconnected from Network PBX
2012-11-21 12:29:33:703 [1.0.7.6] - TCPClient Connected to Network PBX 10.0.14.99:5100
2012-11-21 12:30:05:859 [1.0.7.6] - Synchronizing Extensions, PIN Users, Accounts, Trunks, Phonebook from 2012-11-20 00:00 to 2012-11-20 23:59
2012-11-21 12:30:05:875 [1.0.7.6] - 0 Data records synchronized
2012-11-21 12:30:09:093 [1.0.7.6] - Synchronizing Extensions, PIN Users, Accounts, Trunks, Phonebook from 2012-11-20 00:00 to 2012-11-20 23:59
2012-11-21 12:30:09:093 [1.0.7.6] - 0 Data records synchronized
2012-11-21 12:31:06:375 [1.0.7.6] - Disconnected from Network PBX
2012-11-21 12:31:06:500 [1.0.7.6] - TCPClient Connected to Network PBX 10.0.14.99:5100
2012-11-21 12:31:25:890 [1.0.7.6] - User admin disconnected
2012-11-21 12:31:25:890 [1.0.7.6] - User tngreportschedule disconnected
2012-11-21 12:31:26:156 [1.0.7.6] - Import Thread : Shutting Down..
2012-11-21 12:31:26:171 [1.0.7.6] -  [FRP] Clearing File List.
2012-11-21 12:31:26:468 [1.0.7.6] - Import Thread: Shutting Down.. Completed
2012-11-21 12:31:26:468 [1.0.7.6] - Reports Schedule Thread : Shutting Down..
2012-11-21 12:31:31:296 [1.0.7.6] - Reports Schedule Thread: Shutting Down.. Completed
2012-11-21 12:31:31:296 [1.0.7.6] - SerialThread: Shutting Down..
2012-11-21 12:31:40:609 [1.0.7.6] - SerialThread: Shutting Down.. Completed!
2012-11-21 12:31:40:812 [1.0.7.6] - PluginThread: Shutting Down..
2012-11-21 12:31:45:187 [1.0.7.6] - PluginThread: Shutting Down.. Completed!
2012-11-21 12:31:45:187 [1.0.7.6] - Barring: Shutting Down..
2012-11-21 12:31:45:656 [1.0.7.6] - Barring: Server [20009]: Stopped OK
2012-11-21 12:31:45:656 [1.0.7.6] - Barring: Server Freed
2012-11-21 12:31:45:953 [1.0.7.6] - Barring Object Freed
2012-11-21 12:31:45:953 [1.0.7.6] - Barring: Shutting Down.. Completed!
2012-11-21 12:31:45:953 [1.0.7.6] - Integration: Shutting Down..
2012-11-21 12:31:46:937 [1.0.7.6] - Integration: Server [20003]: Stopped OK
2012-11-21 12:31:46:937 [1.0.7.6] - Integration: Server Freed
2012-11-21 12:31:47:343 [1.0.7.6] - Integration: Object Freed
2012-11-21 12:31:47:343 [1.0.7.6] - Integration: Shutting Down.. Completed!
2012-11-21 12:31:47:343 [1.0.7.6] - FlushThread: Shutting Down..
2012-11-21 12:31:48:312 [1.0.7.6] - Shutdown Flush: 1 Record(s) Written -- OK -- Check:[2DA58CB8AC656846783D3FEE41195338]
2012-11-21 12:31:48:421 [1.0.7.6] - FlushThread: Shutting Down.. Completed!
2012-11-21 12:31:48:437 [1.0.7.6] - CAM: Shutdown
2012-11-21 12:31:48:437 [1.0.7.6] - Clearing CallDataList
2012-11-21 12:31:48:843 [1.0.7.6] - Clearing CallDataList Completed.
2012-11-21 12:31:48:859 [1.0.7.6] - Memory Status Object Destroyed
2012-11-21 12:31:48:859 [1.0.7.6] - Shutdown for ***[C:\Program Files\datatex\tng\tng.exe]*** OK
2012-11-21 12:33:20:234 [1.0.7.6] - Memory Status Object Created
2012-11-21 12:33:20:531 [1.0.7.6] - Available Memory: NPR = 464 ATT = 460294963 TOT = 2137174016 MCC = 992015
2012-11-21 12:33:34:625 [1.0.7.6] - Last File Saved: 1data_1.0.7.6
2012-11-21 12:33:34:625 [1.0.7.6] - Last File Saved Checksum: Check:[2DA58CB8AC656846783D3FEE41195338]
2012-11-21 12:33:34:640 [1.0.7.6] - Loading: C:\Program Files\datatex\tng\data\1data_1.0.7.6.dat
2012-11-21 12:33:34:640 [1.0.7.6] - Loading: Assigned File -- OK
2012-11-21 12:33:34:640 [1.0.7.6] - Loading: Opened File -- OK
2012-11-21 12:33:34:640 [1.0.7.6] - Loading: 1 Record(s) Loaded -- OK -- Check:[2DA58CB8AC656846783D3FEE41195338]
2012-11-21 12:33:34:640 [1.0.7.6] - Loaddata completed: TNGCalldata Count = 1
2012-11-21 12:33:34:640 [1.0.7.6] - Reserving Unused Memory
2012-11-21 12:33:35:140 [1.0.7.6] - Reading Settings
2012-11-21 12:33:35:718 [1.0.7.6] - Settings Read
2012-11-21 12:33:35:843 [1.0.7.6] - TermChar    : [10]
2012-11-21 12:33:35:843 [1.0.7.6] - Com         : COM5
2012-11-21 12:33:35:843 [1.0.7.6] - BaudRate    : 9600
2012-11-21 12:33:35:843 [1.0.7.6] - Bits        : 8
2012-11-21 12:33:35:843 [1.0.7.6] - Parity      : N
2012-11-21 12:33:35:843 [1.0.7.6] - Stop        : 1
2012-11-21 12:33:35:843 [1.0.7.6] - SoftFlow    : 0
2012-11-21 12:33:35:843 [1.0.7.6] - HardFlow    : 0
2012-11-21 12:33:35:843 [1.0.7.6] - COM5 Ready
2012-11-21 12:33:35:843 [1.0.7.6] - SerialThread : 3504
2012-11-21 12:33:35:843 [1.0.7.6] - Integration: Server Created
2012-11-21 12:33:35:843 [1.0.7.6] - Integration Object Created
2012-11-21 12:33:35:859 [1.0.7.6] - Barring: Server Created
2012-11-21 12:33:35:859 [1.0.7.6] - Barring Object Created
2012-11-21 12:33:35:859 [1.0.7.6] - CAM: Created: Trunk Alarm: 0 minutes. Total Alarm: 0 minutes.
2012-11-21 12:33:35:859 [1.0.7.6] - Plugin:  Reading Settings.
2012-11-21 12:33:35:859 [1.0.7.6] - RAW Data logging enabled to 2012-11-21 13:26
2012-11-21 12:33:35:859 [1.0.7.6] - Plugin: Loading Rules..
2012-11-21 12:33:35:984 [1.0.7.6] - Plugin: Loading Rules.. Completed.
2012-11-21 12:33:36:140 [1.0.7.6] - Loading Plugin: C:\Program Files\datatex\tng\plugins\PSamsung_7400.dll
2012-11-21 12:33:37:250 [1.0.7.6] - PSamsung_7400, v2008.11.10.1 loaded successfully
2012-11-21 12:33:37:453 [1.0.7.6] - Loading Scheduled Reports..
2012-11-21 12:33:37:453 [1.0.7.6] - Loading Scheduled Reports.. Completed.
2012-11-21 12:33:37:468 [1.0.7.6] - User tngreportschedule connected from 127.0.0.1
2012-11-21 12:33:37:500 [1.0.7.6] -  [FRP] Clearing File List.
2012-11-21 12:33:37:500 [1.0.7.6] - Verifying Buffer...
2012-11-21 12:33:38:328 [1.0.7.6] - Startup for ***[C:\Program Files\datatex\tng\tng.exe --Normal-- ]*** OK
2012-11-21 12:33:38:328 [1.0.7.6] - Integration: Server [20003]: Started OK
2012-11-21 12:33:38:328 [1.0.7.6] - Barring: Server [20009]: Started OK
2012-11-21 12:33:42:609 [1.0.7.6] - Comport Responded, checking for TNG Buffer...
2012-11-21 12:33:47:656 [1.0.7.6] - Valid Buffer Found.
2012-11-21 12:33:52:765 [1.0.7.6] - Exchange Library      : Verifying Versions...
2012-11-21 12:33:54:140 [1.0.7.6] - Exchange Library      [ver 2009.08.01.01]: Version Ok!
2012-11-21 12:33:56:781 [1.0.7.6] - 22388 exchange entries loaded.
2012-11-21 12:33:56:843 [1.0.7.6] - TCPClient Connected to Network PBX 10.0.14.99:5100
2012-11-21 12:35:59:968 [1.0.7.6] - User admin connected from 10.0.14.13
2012-11-21 12:36:10:593 [1.0.7.6] - RecieveNetworkData: Socket Error # 10054[13][10]Connection reset by peer.
2012-11-21 12:36:10:593 [1.0.7.6] - Disconnected from Network PBX
2012-11-21 12:36:10:718 [1.0.7.6] - TCPClient Connected to Network PBX 10.0.14.99:5100
2012-11-21 12:36:40:718 [1.0.7.6] - Disconnected from Network PBX
2012-11-21 12:36:40:843 [1.0.7.6] - TCPClient Connected to Network PBX 10.0.14.99:5100
2012-11-21 12:37:43:546 [1.0.7.6] - Disconnected from Network PBX
2012-11-21 12:37:43:671 [1.0.7.6] - TCPClient Connected to Network PBX 10.0.14.99:5100
2012-11-21 12:39:30:375 [1.0.7.6] - Disconnected from Network PBX
2012-11-21 12:39:30:500 [1.0.7.6] - TCPClient Connected to Network PBX 10.0.14.99:5100
2012-11-21 12:44:24:296 [1.0.7.6] - RecieveNetworkData: Socket Error # 10054[13][10]Connection reset by peer.
2012-11-21 12:44:24:296 [1.0.7.6] - Disconnected from Network PBX
2012-11-21 12:44:45:515 [1.0.7.6] - ConnectToNetworkPABX: Host[10.0.14.99] Port[5100]Socket Error # 10060[13][10]Connection timed out.
2012-11-21 12:46:10:734 [1.0.7.6] - TCPClient Connected to Network PBX 10.0.14.99:5100
2012-11-21 12:46:34:437 [1.0.7.6] - Disconnected from Network PBX
2012-11-21 12:46:34:562 [1.0.7.6] - TCPClient Connected to Network PBX 10.0.14.99:5100
2012-11-21 12:46:51:546 [1.0.7.6] - User admin disconnected
2012-11-21 12:46:51:546 [1.0.7.6] - User admin connected from 10.0.14.13
2012-11-21 12:47:08:890 [1.0.7.6] - Synchronizing Extensions, PIN Users, Accounts, Trunks, Phonebook from 2012-11-20 00:00 to 2012-11-20 23:59
2012-11-21 12:47:08:890 [1.0.7.6] - 0 Data records synchronized
2012-11-21 12:49:06:234 [1.0.7.6] - Disconnected from Network PBX
2012-11-21 12:49:06:359 [1.0.7.6] - TCPClient Connected to Network PBX 10.0.14.99:5100
2012-11-21 12:49:56:968 [1.0.7.6] - Disconnected from Network PBX
2012-11-21 12:49:57:093 [1.0.7.6] - TCPClient Connected to Network PBX 10.0.14.99:5100
2012-11-21 12:53:55:234 [1.0.7.6] - User admin disconnected
2012-11-21 12:53:55:234 [1.0.7.6] - User admin connected from 10.0.14.13
2012-11-21 12:54:47:750 [1.0.7.6] - Reading Settings
2012-11-21 12:54:47:890 [1.0.7.6] - RecieveNetworkData: Disconnected.
2012-11-21 12:54:47:890 [1.0.7.6] - Disconnected from Network PBX
2012-11-21 12:54:47:890 [1.0.7.6] - Settings Read
2012-11-21 12:54:48:000 [1.0.7.6] - TermChar    : [10]
2012-11-21 12:54:48:000 [1.0.7.6] - Com         : COM5
2012-11-21 12:54:48:000 [1.0.7.6] - BaudRate    : 9600
2012-11-21 12:54:48:000 [1.0.7.6] - Bits        : 8
2012-11-21 12:54:48:000 [1.0.7.6] - Parity      : N
2012-11-21 12:54:48:000 [1.0.7.6] - Stop        : 1
2012-11-21 12:54:48:000 [1.0.7.6] - SoftFlow    : 0
2012-11-21 12:54:48:000 [1.0.7.6] - HardFlow    : 0
2012-11-21 12:54:48:000 [1.0.7.6] - COM5 Ready
2012-11-21 12:54:48:000 [1.0.7.6] - TCPClient Connected to Network PBX 10.0.14.99:5100
2012-11-21 12:54:48:000 [1.0.7.6] - Raw Data Logging Permanently Enabled
2012-11-21 12:54:48:015 [1.0.7.6] - Import Raw Data Disabled
2012-11-21 12:54:48:031 [1.0.7.6] - ApplyGeneralSettings: OK - Tech Saving=True!
2012-11-21 12:58:12:437 [1.0.7.6] - Reading Settings
2012-11-21 12:58:12:562 [1.0.7.6] - Disconnected from Network PBX
2012-11-21 12:58:12:562 [1.0.7.6] - RecieveNetworkData: Not Connected
2012-11-21 12:58:12:562 [1.0.7.6] - Settings Read
2012-11-21 12:58:12:671 [1.0.7.6] - TermChar    : [10]
2012-11-21 12:58:12:671 [1.0.7.6] - Com         : COM5
2012-11-21 12:58:12:671 [1.0.7.6] - BaudRate    : 9600
2012-11-21 12:58:12:671 [1.0.7.6] - Bits        : 8
2012-11-21 12:58:12:671 [1.0.7.6] - Parity      : N
2012-11-21 12:58:12:671 [1.0.7.6] - Stop        : 1
2012-11-21 12:58:12:671 [1.0.7.6] - SoftFlow    : 0
2012-11-21 12:58:12:671 [1.0.7.6] - HardFlow    : 0
2012-11-21 12:58:12:671 [1.0.7.6] - COM5 Ready
2012-11-21 12:58:12:687 [1.0.7.6] - ConnectToNetworkPABX: Host[10.0.14.99] Port[5100]Already connected.
2012-11-21 12:58:12:687 [1.0.7.6] - ConnectToNetworkPABX: Host[10.0.14.99] Port[5100]Socket Error # 10038[13][10]Socket operation on non-socket.
2012-11-21 12:58:12:687 [1.0.7.6] - TCPClient Connected to Network PBX 10.0.14.99:5100
2012-11-21 12:58:12:687 [1.0.7.6] - Raw Data Logging Permanently Enabled
2012-11-21 12:58:12:703 [1.0.7.6] - Import Raw Data Disabled
2012-11-21 12:58:12:718 [1.0.7.6] - ApplyGeneralSettings: OK - Tech Saving=True!
hendrik
Re: Samsung 7030 No Call Detail
Postby Belinda Frick » Mon Nov 26, 2012 4:33 pm
