Please use plugin in forum post -
Which plugin do I use for the LG LDK300 IP?In the rawdata your test call to the Datatex Call Centre shows the pin codes 'P0006'. This is the values you must configure under 'Configure Users' in TNG. If you enter a different pin code when you dial, you need to get the index list that represents your pin codes from your PABX support company. Once this is configured your user names will display when using the pin code.
If you have only a few pin codes, you can ask each user to make a test call using their pin code (they do not need to give the pin code to you) and then check in the rawdata which index code is given off. Configure the index code with their user name.
