Hi,
A tng is working with Panasonic tda 30 system. Tng is working fine. They wanted to integrate the system with LMS. I Send all the details i can get from this site and TNG Export file too.
they shoot me with these question. HELP Please.
.1. There were no account codes in the file, how do these get into the TNG system? We have an export of account codes with details in it. This is how we work with most other companies that do a similar thing to you. Attached is a sample of the file created. (The file will be located in the DsApps\Interface\Exports folder. As soon as a new matter is created or changed its entered into this file so you can import it into your system.
2. We need to know the location of the file you give us. All other systems we have interfaces with are able to place the file in the DsApps\Interface\Imports folder, if you could that it would be most helpful else the client will need to copy the file manually into the folder.
3. We need clarification on the actual file created from TNG. According to the details provided you create a file for the day. Can you rather create a file called TNG.txt and place all entries into that file. When we import those entries into LMS, we will then rename the file to TNG.bak so those entries will not be imported again causing duplications. Imports can then be run as the client wishes either every day or more than once a day or every few days. We find this works best for all our clients and would be the same way we receive the information from Topaz (in a file called Caseware.DAT). If you cannot do that please clarify how those entries get into the file, is it automatically as the entry is done or is there an export done?
Regards
