Sometimes the anti-virus will pick up a virus when it does its decrypting, etc. even if it is not a virus.
We run anti-virus software at our site and has not picked up a problem with the install. You can disable the anti-virus software to do the download.
If you are unsure you can use the following link to test the download:
http://virusscan.jotti.org/enIt will run it through various anti-virus software and you can decide based on the outcome if you trust it.
There are 2 links to download the TNGLive install/updates from:
- Our website:
Latest update releases of TNG - as of 2013-08-01
- Our forum:
Last TNG releases for 2012
NOTE: To download attachments from the forum you need to be registered and logged in.
