Force CSV processing?
Postby aragon » Mon Nov 25, 2013 2:03 pm
Hi. We use TNG with a CSV file based CDR import. Normally TNG processes the file automatically at 1:00 in the morning every day, but we need to trigger a process run manually. Is this possible?
aragon
Re: Force CSV processing?
Postby Belinda Frick » Mon Nov 25, 2013 7:51 pm
Please attached tng.log file as discussed telephonically.
We suggest using the 'Asterisk CSV File Import' option.
The format of the CSV required is the cdr-custom. Asterisk has two options cdr-custom and master, both writes out a file named master.csv. Be sure to use the file in the cdr-custom folder. For TNG configuration with Asterisk, please refer to forum post:
TNG and Asterisk: Suggested setup
Postby aragon » Tue Nov 26, 2013 5:13 pm
All came right. When I checked later the data was showing, so unfortunately I'm not sure what the issue was. Thanks for your attention.
aragon
