by Jacques@4dt.co.za » Tue Nov 26, 2013 3:41 pm
Unable to syncronise data to Far South
Jacques@4dt.co.za
by Belinda Frick » Tue Dec 03, 2013 2:13 pm
The Far South install includes the default settings for TNG. Your format of the 'master.csv' should then be correct.
From your tng.log:
- Code: Select all
2013-11-26 15:43:45:770 [1.1.0.7] - AMI Exception:ProcessAMIEvent: ProcessDial 3: Access violation at address 0818B392, accessing address 000000A9
2013-11-26 15:43:45:770 [1.1.0.7] - AMI Exception:Event: Dial[10]Privilege: call,all[10]SubEvent: End[10]Channel: SIP/5753-000006ff[10]UniqueID: 1385473395.2490[10]DialStatus: NOANSWER[10]
For the AMI errors logged, please refer to forum post:
TNG4* Custom CSV is correct format but not logging calls
