Belinda Frick wrote:Export files:
There are no configuration to set TNG to write out the files in the export folder, it does it by default and cannot be disabled. If you have call details for Oktober in TNG, then the same entries should be in a file in the export folder also. TNG does not auto delete these files or have an option to delete it.
Well, it's not working.
Belinda Frick wrote:The calls in the database is auto purged when 99% call capacity has been reached and it only purges down to 80% in use. You can check these figures on the Call List page. I do not think an auto purge took place.
Yep, that's not the problem.
Belinda Frick wrote:If the Oktober files are not present in the export folder, either access changed and it could not write it out or the files was manually deleted or something happened on the server. You did not perhaps have space issues on the server?
No space issues, disk has 58 GB free space.
Belinda Frick wrote:If TNG was installed as root, you should not have any access issues - unless it was changed thereafter.
It was, and is still running as root.
Belinda Frick wrote:If TNG is showing calls updating live on the Call List page, you must have a export file for today also. If not, please check the access for TNG to create a file and write to it.
Live calls are updating, but no export files.
Belinda Frick wrote:Call details before 29 October 2013:
If you have the master.csv files in the processed folder for the days before 29 October 2013, you can re-import it as per link in previous post. I would suggest to do only one or two days, check if you can pull the reports. If not, it might be that the data file is damaged and it must be blanked and all the call details re-imported.
I have tried re-importing to a blank database. The re-import showed calls before Oct 29 in the Live Call list, but reports were still time limited to after Oct 29.
And surprise surprise, today the time limit is Oct 31. Every passing day the time limit shifts by one day. This must be a time limit restriction in TNG's report generator. Please could you have proper look at this on your side?
Thanks.
