Gerhard Omuthea Namibia
Postby turnkey » Thu Jan 30, 2014 1:07 pm
Belinda
hier is die file gezip wat jy soek.
Bel maar. moet nog vanaand in Rundu wees
turnkey
Re: Gerhard Omuthea Namibia
Postby Belinda Frick » Thu Jan 30, 2014 2:36 pm
The 'dtxPanasonicTDA.log' has the following entries:
[2014-01-30 11:47:43] Reconnecting to TAPI, please wait...
[2014-01-30 11:47:43] lineInitializeExA - Complete.
[2014-01-30 11:53:43] Reconnecting to TAPI, please wait...
I would suggest checking that your USB cable is connected to the Panasonic (not the USB cable connected to the TNG buffer, which has a serial cable to the PABX for call details) - the programming cable, it handles the bar and unbar command(not call details).
Once confirmed it is connected securely, please shut the PC down via Windows and power it up. This is to ensure all resource is available(you mentioned it was slow updating) and that all the services started up correctly.
Make a test call. If you still get the same entries in the 'dtxPanasonicTDA.log' then there is an issue connecting to the Panasonic TAPI. To test is TAPI is working refer to point 2 in the forum post:
TNG callbarring and the Panasonic TDA
The link has a tool you can download to do testing to see if TAPI is receiving events from the PABX.
