Panasonic TD 1000
Panasonic TD 1000
Postby kent » Tue Apr 15, 2014 3:09 pm
Hi,
I need a driver for the Panasonic TD 1000 PABX, can you help?
kent
Re: Panasonic TD 1000
Postby Belinda Frick » Thu Apr 24, 2014 12:10 pm
We do not have a plugin for the Panasonic TD 1000.
You can check if the rawdata is the same as the TDA series. Refer to forum post for rawdata example and the plugin:
Which plugin do I use for the Panasonic TDA?
