When installing the TNG buffer on Windows Server 8 64 bit, the buffer installs as a USB Serial Converter.
When trying to manually update the installed USB Serial Converter driver to Windows 8 64bit, the response is the correct driver is already installed. The same happens when uninstalling and reinstalling the buffer.
Even when programming the buffer with the FTDI Tool, it makes no difference.
The buffer installs correctly on standard Windows 8.1
