Waiting on Dial Plan and Peer List
Postby Dcdata » Mon Jan 19, 2015 12:09 pm
Hi guys,
I hope all is well on your side.
We have another site that is unable to import the latest call data, and we are seeing the following in the TNG log:
2015-01-19 12:00:25:279 [1.1.1.12] - [AMI LOG] - Waiting on Dial Plan and Peer List
TNG is installed on a separate system but it has been working well for a long time until now.
The manger settings are as follows:
[tng]
secret = ****
deny=0.0.0.0/0.0.0.0
permit=10.0.0.124/255.255.255.255 127.0.0.1/255.255.255.255
read = system,command
write = system,command
writetimeout=10000
TNG version: 1.1.1.12
Please may I ask for your urgent assistance?
Dcdata
Re: Waiting on Dial Plan and Peer List
Postby Dcdata » Mon Jan 19, 2015 1:25 pm
Further to my initial post:
When running TNG in the foreground (minus the 'D' option), I see the following:
ChannelInExtensions: channel="1221" cleanExt="1221" aliasExt="1221"
ChannelInExtensions: channel="1220" cleanExt="1220" aliasExt="1220"
Also, the "ami.txt" log shows that communication between the TNG system and Asterisk is taking place - there are stacks of log entries similar the following:
[AMI] TimeStamp: 13:23:52.808
Event: PeerStatus
Privilege: system,all
Peer: SIP/1126
PeerStatus: Registered
[AMI] TimeStamp: 13:23:51.806
Response: Success
Channeltype: SIP
ObjectName: 1180
ChanObjectType: peer
SecretExist: Y
MD5SecretExist: N
Context: from-internal
Language:
Many thanks.
David Wilson
Dcdata
Postby Lee Hendricks » Mon Jan 19, 2015 3:19 pm
Hi David
Please attach a copy of the raw data to investigate further
Also for what PABX this is and what plugin was used
Lee Hendricks
Postby Dcdata » Mon Jan 19, 2015 3:31 pm
Thanks Leon.
This client's PBX system is "Asterisk-1.4.26.1".
Please find the "ami.txt.zip" file attached.
I am not sure what plugin is being used but did find the following in the "tng.ini" config file:
[PLUGIN]
localnumber=********** (hidden)
localcode=033
countrycode=27
internationalaccesscode=00
pluginName=new installation
pluginPath=./plugins/
defaultratebook=za_vodacom_talk500
swoppinaccount=0
lograwdata=99999
Branch Code=033
autoupdatenames=0/
We are using the CSV import method.
Please shout if you have any further queries.
Dcdata
Postby Dcdata » Tue Aug 04, 2015 5:06 pm
Hi Guys
We had the exact same issue with another client. Rebooting the PBX has not helped resolve the issue. The clients don't receive any data in their TNG reports. We see the same error as above.
What information do you need to help us resolve this issue?
Dcdata
Postby Dcdata » Thu Aug 06, 2015 9:06 am
This info from the TNG logs appears every 15 minutes.
2015-08-06 08:59:07:068 [1.1.1.12] - [AMI LOG] - Waiting on Dial Plan and Peer List [Repeated 14 times]
2015-08-06 08:59:07:068 [1.1.1.12] - [AMI LOG] - No Dialplan/Peer List Received since last request. Reloading...
2015-08-06 08:59:07:068 [1.1.1.12] - [AMI LOG] - Requesting Dialplan...[Process Reload]
2015-08-06 09:00:00:633 [1.1.1.12] - [AMI LOG] - Dialplan Processed.
2015-08-06 09:00:05:637 [1.1.1.12] - [AMI LOG] - Waiting on Dial Plan and Peer List
PBX: Asterisk 1.4.26.1
The symptoms are exactly as described below. Please can you assist us with resolving this issue. If we can help you with any further information please let us know.
Dcdata
Postby Dcdata » Thu Aug 13, 2015 9:36 am
Hi Lwanda
Thank-you for your instructions.
I have attached the ami.txt file along with the log file for today. I have included all the *.ini files from the plugins folder.
Please let me know if you need anything further or have any more instructions.
John Fordyce
Dcdata
Postby Luanda_Junzi » Thu Aug 13, 2015 10:05 am
Thank you John
I will investigate and update the post during the day.
Regards
Lwanda
Luanda_Junzi
Postby Luanda_Junzi » Fri Aug 14, 2015 10:44 am
Good day John
Can you upgrade to 1.1.1.13
Refer to TNG 1.1.1.13 (Asterisk change)
kind regards
Luanda
Luanda_Junzi
Postby Dcdata » Fri Aug 14, 2015 1:02 pm
Thank-you for your help Luanda, the upgraded version fixed the issue and the client was able to update.
Dcdata
Next
