Waiting on Dial Plan and Peer List
Re: Waiting on Dial Plan and Peer List
Postby Dcdata » Fri May 13, 2016 11:59 am
Good morning Luanda.
We recently installed 1.1.1.13 of TNG for Asterisk and are still experiencing the same problem.
TNG runs fine for a couple days but then stops receiving inbound call records. The logs indicate numerous entries similar to the following: "2016-05-13 11:39:52:472 [1.1.1.13] - [AMI LOG] - Waiting on Dial Plan and Peer List [Repeated 26 times]"
Killing the tng process and restarting tng seems to address the issue for a day or two until the issue then re-occurs.
Please may I ask for your very urgent assistance?
Dcdata
Postby Luanda_Junzi » Mon May 16, 2016 12:00 pm
Hi John.
Sorry for the late responce.
TNG 1.1.1.13 was made to address this wating on dial list issue.
Can you grep the errors before the error occurs and after.
How many extensions you have configure.
Can I have the specs of the Server
also grep the 1st Dial up entry and the last
I want to escalate the query but i need more info to do so.
Thank you Regards
Luanda
Luanda_Junzi
Postby Leon van Heerden » Tue May 17, 2016 1:55 pm
Hi,
TNG also has to re-process the dial plan whenever changes are made to the dial plan. This is done automatically when the dialplan reloads.
Is the dial plan very big?
Are there alot of peer entries?
Leon
Previous
