Panasonic KX-TES 824 Account Codes Not Reflecting
Postby danielh » Mon Mar 02, 2015 8:25 am
TNG not showing account codes but shows in raw data.
No data in ini folder.
danielh
Re: Panasonic KX-TES 824 Account Codes Not Reflecting
Postby Luanda_Junzi » Mon Mar 02, 2015 1:08 pm
Good Day danielh.
Thank you for your query.
I did simulated your problem.this was my finding.
you'll have to uncheck "Swop Accountcode and Pincode fields" on Communication Configuration.
please note that tng makes provision of pin codes and account code - this depends on the PBX
Pin codes tipically codes that allow you to dial out
account code is used to identify a call.e.g link the call to a client
Luanda_Junzi
