Cannot pull Department report by Extension
Postby Lee Hendricks » Thu Apr 09, 2015 10:34 am
Sent on behalf of Annatjie van der Sandt - Route Control Centre Manager
I am trying to get the call cost split for the telephone account and all I get is a blank report, see below
Lee Hendricks
Re: Cannot pull Department report by Extension
Postby Luanda_Junzi » Tue Apr 14, 2015 12:44 pm
These were the steps followed to resolve Annatjie Van Der Sandt TNG issue.
Queried for the raw data files to simulate.
they didn't have raw data files, because they were running the TNG version 1.0.6.0.
Solution
To retrieve call details imported export data (C:\Program Files\datatex\tng\export).
To clear the corrupt database, the TNG file must first be blanked before import of export files.
Steps:
  1. Stop TNG service blanked the extension files.
    No report result if department selected
  2. Blank the TNG call details:
    How do I blank the TNG call details?
  3. How do I re-import purged/exported data into TNG?
Pulling of reports
If you pull a report e.g Extension Report It will not generate only if u selected a criteria e.g Department then you don’t specify which department you want to generate report for.
Also see the attached screenshot for a report where department was selected as criteria but not department was selected
Luanda_Junzi
