by Lindisa Bajisi23 » Tue Aug 04, 2015 5:03 pm
Please follow the following steps to test your buffer.
- Stop the TNG service
- Connect to putty
How to Connect to a Buffer using Putty - Select the connection type Serial and enter the correct comport and baudrate
- type
- Code: Select all
CODE 1111
and press enter - If it has the key it will display the
- Code: Select all
E3D0
code
- If it displays a different code from "E3DO" the buffer has to be returned to Datatex to upgrade the buffer with new programming and serial number.
Lindisa Bajisi23
