Afternoon,
We have a client running TNG with a buffer.
Win 7 Pro x64 SP 1, fully updated.
TNG software is 1.1.1.12
The live call log as well as reports display all the incoming numbers and destination as "INCOMING".
The client wants it changed.
This is what I have done:
-> Renamed the exchange file
-> Made a backup of exchange file in another directory and deleted the exchange.dat file
-> Made backup of the data folder in remote directory, cleared all the content.
-> Re-synced via TNG software.
-> Uninstalled / Re-installed and updated the Radius service.
-> Updated the buffer driver
The client wants reporting on incoming calls, outgoing calls and reporting between extensions.
The reporting between extensions and outgoing calls seem to be working fine, I am having trouble with the incoming call reporting
Kindly assist as I am not sure what else can be done to achieve the goal.
I have attached the files I believe you require.
Thank you in advance for the assistance.
JJ.
