TNG appears to be adding an extra 27 prefix
Postby Dcdata » Wed Sep 02, 2015 10:45 am
Hi guys,
How are you keeping?
When dialing numbers that start with a 27 prefix, it seems that TNG is adding an additional 27 prefix in the report.
Please see the Master.csv excerpt below and the screenshot attached.
"hidden","","27824147413","from-internal","Console/dsp","SIP/voxjhb-000fa456","Dial","SIP/voxjhb/27824147413,300,Tt","2015-09-02 10:40:45","","2015-09-02 10:40:51","6","0","NO ANSWER","DOCUMENTATION","","1441183245.1425769",""
Please may I ask for your assistance?
Many thanks.
Dcdata
Re: TNG appears to be adding an extra 27 prefix
Postby Lindisa Bajisi23 » Wed Sep 02, 2015 11:40 am
Hi Dcdata
Please verify if your area information has a single 27 like in the screenshot:
Lindisa Bajisi23
Postby Dcdata » Fri Sep 04, 2015 8:06 am
Thanks for your reply Lindisa.
Yes. We do already have that.
Dcdata
Postby Lindisa Bajisi23 » Fri Sep 04, 2015 10:06 am
Hi Dcdata
Please attach the following files:
Raw data
ini.rule
tng.ini
Lindisa Bajisi23
Postby Dcdata » Fri Sep 18, 2015 7:21 am
Hi Lindisa,
Please may I ask for urgent feedback on this?
Dcdata
Postby Lindisa Bajisi23 » Fri Sep 18, 2015 11:16 am
Hi there
On the private message i have requested for the raw.txt file so i can simulate the problem and provide the feedback.
Please if you cant find the data from the logs try finding it on export folder.
Lindisa Bajisi23
