Segmentation fault after update
Postby Dcdata » Wed Sep 09, 2015 5:30 pm
Hi Guys
After running the update tng-update-1_1_1_12_2014 on a tng system we get a segmentation fault.
I ran the following command:
strace -f ./tng 2> full.log
The full.log file is attached to this post.
Please can you help us determine the reason why we are getting a segmentation fault.
Dcdata
Re: Segmentation fault after update
Postby Leon van Heerden » Fri Sep 11, 2015 3:56 pm
Hi,
Did you do an export for LANG=C before you ran the TNG like this?
So can you try this:
export LANG=C
strace -f -s 255 ./tng 2> trace.log
Leon
Postby Dcdata » Mon Sep 14, 2015 8:42 am
Hi Leon
Thank-you for your reply.
We ran the code as you asked and have attached the trace.log file.
Please le us know if we can assist you any further.
Dcdata
Postby Leon van Heerden » Tue Sep 22, 2015 8:55 am
I have looked at this log and can't see what is causing the crash.
I am investigating further and will give more feedback/suggestions shortly.
Leon
Postby Leon van Heerden » Mon Sep 28, 2015 12:26 pm
This issue was the dial code that was used to build the Exchange.Dat file, was not a known number. This normally causes a blank database to be build in windows, but it seems to cause the Linux version to crash with this segmentation fault.
I looked up a number int he same area as this client and entered the first 6 digits from the Telkom number as the LocalNumber. There after the exchange build normally and TNG started.
[PLUGIN]
localnumber=0114440000
localcode=011
The error was actually displayed in the tng.log when it started.
