Leading 0 missing; billing as international call on outgoing
Postby kalr » Thu Feb 18, 2016 10:11 am
Hi there
I re-installed my copy of TNG on asterisk. The leading zero is missing on outgoing calls e.g instead off 0112341234 it is recorded as 112341234 and bills it as international. Under settings I have unchecked the option to remove leading zero; but it does not change anything.
Please advise.
Kind regards
Kal
kalr
Re: Leading 0 missing; billing as international call on outg
Postby Luanda_Junzi » Thu Feb 18, 2016 10:15 am
Hi Kalr
Can you Please attach Area Information screenshot
On TNG under general settings.
Regards
Luanda
Luanda_Junzi
Postby kalr » Thu Feb 18, 2016 10:29 am
Thanks Luanda
please see the attached
kalr
Postby Luanda_Junzi » Thu Feb 18, 2016 10:40 am
Hi Karl
can you try this one.
Killall tng
rm exchange.dat file.
LANG=C
./tnglive -D
Regards
Luanda
Luanda_Junzi
Postby kalr » Thu Feb 18, 2016 11:11 am
Hi Luanda
I have made the changes. Seems it stopped downloaded new data. the RAW file is no longer being updated.
kind regards
Kal
kalr
Postby Luanda_Junzi » Thu Feb 18, 2016 11:13 am
Hi Kalr
Can you call support line and grant me team viewer access.
Luanda
Luanda_Junzi
