TNG Alcatel OmniPCXOffice Office Link Driver Service Plugin
Postby ZanePhelan » Fri Apr 15, 2016 11:54 am
Hi Support,
Have a site that can only access CDR/SMDR data via a Alcatel-Lucent Office Service, that writes out the call data to a xml file. The PBX is a Omni PCX Office
None of the standard TNG plugins for the Alcatel range work ~ tested all available plugins using pabx3 rawdata import.
Could you please check the attached output file from the Office Link Driver Service <TicketCollector.txt> and confirm if you have a plugin available?
Thanks
Zane
ZanePhelan
Re: TNG Alcatel OmniPCXOffice Office Link Driver Service Plu
Postby Luanda_Junzi » Fri Apr 15, 2016 12:28 pm
Dear Zane
Thank you for your query.
You can change the PABX output format to Standard on the pabx site.it will write an out like this bellow
***** A7855 --> N02 31/08/06 16:15 00:01:02    0 ST        8879602................... M 00:00 0.00       ................ Mathilda........ T     ********* A7855     N002
***** A7842 --> N03 31/08/06 16:29 00:02:09    0 ST        0860345000................ M 00:00 0.00       ................ Felicia......... T     ********* A7842     N003
A7842 A7842 <-- N03 31/08/06 16:34 00:00:08    0 ST        .......................... M 00:12 0.00       ................ Felicia.........       A7842     A7842     N003
A7841 A7841 <-- N01 31/08/06 16:35 00:00:29    0 ST X      .......................... M 00:15 0.00       ................ Yvette..........       A7841     A7841     N001
Then you can use Omni PCX Office plugin to process data.
unfortunately we can't write a plugin to process xml files right now, it will be discussed internally if you wish to reprocess your historical data.
Regards
Luanda
Luanda_Junzi
Postby ZanePhelan » Fri Apr 15, 2016 1:36 pm
Thanks Luanda,
The usual route to connect to the Omni PCX Office is to connect a serial cable to a V24 port that is part of the switchboard console. This is unfortunately not possible at this site and the only option to get call data is via the Office Link river Service, which write the call data to the xml file.
Could you please discuss this requirement internally as the only available option currently is via the xml file import route.
Thanks
Zane
ZanePhelan
Postby Luanda_Junzi » Fri Apr 15, 2016 3:02 pm
Thank you Zane.
We will discuss internally and I will forward the xml file to development, but I can give you feedback after 10 working days in regards to the way forward.
However once we have the solution you can reprocess and re cost all of your data.
Kind Regards
Luanda
Luanda_Junzi
Postby Luanda_Junzi » Tue Apr 26, 2016 12:37 pm
Hi Zane
I have forwarded the xml file to development, once I get a feedback I will update the post.
Regards
Luanda
Luanda_Junzi
Postby ZanePhelan » Thu Apr 28, 2016 4:59 pm
Hi Luanda
Any feedback or timeframes?
Thanks
Zane
ZanePhelan
Postby Luanda_Junzi » Thu May 05, 2016 2:44 pm
Hi Zane
Thank you for your patience , the plugin is ready.
Please find attached plugin extract to the plugin folder.
Regards
Luanda
Luanda_Junzi
Postby ZanePhelan » Thu May 05, 2016 3:35 pm
:o
Thanks Luanda
Will confirm if all is ok
ZanePhelan
Postby ZanePhelan » Wed May 11, 2016 5:08 pm
Working.
Thanks
ZanePhelan
