missing digit in the report
Postby teenu » Tue Apr 26, 2016 11:11 am
we have a TNG software running but when we try to extract the report some of the leading numbers are not showing. we have some outgoing numbers which have leading numbers of 31 but in the report it doesn't show.our country code is 267 and instead of the report to show e.g 2673190000, it will show 26790000. some other leading numbers from 32xxxxx, 33xxxxx, 34xxxxx,35xxxxx,36xxxxx,37xxxxx,38xxxxx,39xxxxx are showing correctly with no omission.
teenu
Re: missing digit in the report
Postby Luanda_Junzi » Tue Apr 26, 2016 11:16 am
Dear Teenu
Thank you for your querry.
Can you attach a screenshot of the report and a screenshot of the Area Information under general settings on tng.
Regards
Luanda
Luanda_Junzi
Postby teenu » Thu Apr 28, 2016 11:51 am
Account Detail Report
Selection Criteria
Accounts Sampath Kumar
Dates Selected Printed by TNG from Datatex Dynamics CC
2016-02-18 00:00:00 - 2016-03-17 11:59:59 (Time Range - Between Dates) 2016-03-18 12:00:17
________________________________________
Account: Sampath Kumar
Date Time Ext User/Ext Name Number Destination Outcome Ring Time Duration Cost
2016-02-18 14:51:12 420 Sampath 26760150 NATA - (BW) O_NORMAL 00:12 00:03:27 P2.51
2016-02-18 14:53:13 420 Sampath 26760150 NATA - (BW) O_NORMAL 00:13 00:01:08 P0.83
2016-03-03 09:16:19 420 Sampath 2673913913
GABORONE - (BW) O_NORMAL 00:19 00:00:53 P0.64
2016-03-04 14:28:09 420 Sampath 2676865404
NATA - (BW) O_NORMAL 00:09 00:00:55 P0.67
2016-03-07 09:03:09 420 Sampath 2673708010
GABORONE - (BW) O_NORMAL 00:09 00:00:33 P0.40
2016-03-07 10:00:06 420 Sampath 2673710101
GABORONE - (BW) O_NORMAL 00:06 00:01:03 P0.76
2016-03-08 10:39:22 420 Sampath 2673912655
GABORONE - (BW) O_NORMAL 00:22 00:03:01 P2.20
2016-03-09 15:55:00 406 Corporate Training 26723 FRANCISTOWN - (BW) O_NORMAL 00:00:19 P0.22
2016-03-15 11:22:29 420 Sampath 911426405678 INDIA - (IN) O_NORMAL 00:29 00:03:35 P7.63
2016-03-15 16:42:08 420 Sampath 26763601 NATA - (BW) O_NORMAL 00:08 00:02:30 P1.82
Total for account : Sampath Kumar Inc Calls/ Out Calls : 0 / 10 00:17:24 P17.68
Grand Totals: Inc Calls / Out Calls : 0 / 10 00:17:24 P17.68
teenu
Postby Luanda_Junzi » Thu May 05, 2016 2:46 pm
Dear Teenu
Can you please call our support line and grant me access to your machine so I can assist.
Kind Regards
Luanda
Luanda_Junzi
Postby teenu » Fri Jun 17, 2016 11:43 am
i will go the site and call ,,,, next week
thanks
teenu
