Report on internal calls in TES
Postby Luanda_Junzi » Mon May 16, 2016 12:17 pm
QUERY:
How do I pull a report on internal calls in TES?
OVERVIEW:
Call details available are PABX dependant, meaning if the PABX does not supply internal calls then the software cannot report on it.
TES does not have a report for INTERNAL calls.
TNG collects call details for TES.
TNG can report on INTERNAL calls provided the call details is received from PABX.
STEPS: Pulling a report for INTERNAL calls in TNG
  1. Log into TNG
    The URL is http://127.0.0.1:7080
    Where '127.0.0.1' is the TNG IP address.
  2. Go to the REPORTS page.
  3. Select Extension detail report .
  4. Select "Trunks"
    TNG will Give of option to select specific trunk.
    You need to select Internal.
  5. Select the date you want to pull report for click apply
  6. Then Preview the report.
Luanda_Junzi
