by teenu » Fri Jul 29, 2016 9:13 am
Hi Forum,
please see the attachment showing extra digit after cell numbers,
teenu
by Luanda_Junzi » Fri Jul 29, 2016 9:20 am
Hi Teenu
Thank you for your query.
Can you please chek the call record for 267767647201212 on raw.txt file, TNG doesn't add extra digits on any record only translate whatever it receives from the PABX.
Regards
Luanda
Luanda_Junzi
