TNG Plugin with Nortel CS 1000 rel 7.6
Postby conrad13 » Mon Sep 26, 2016 1:48 pm
The client uses a Nortel CS1000 rel 7.6 with TNG ver 1.1.1.11
Plugin: PMeridian_Opt11C_New.dll
Some users dial out with pin codes, some users don't have pin codes
Intermittantly TNG will show that a call was made from a ext not using pin code, but that a call was made by a users pin code. The user that apparently made the call did not have access to that specific ext.
Raw File 1 - data from a normal day.
Raw File 2- Data with a problematic call. Ext 8002, Time 13:12:51
Can you please check the plugin
conrad13
Re: TNG Plugin with Nortel CS 1000 rel 7.6
Postby Luanda_Junzi » Wed Oct 05, 2016 2:36 pm
Hi Conrad
Sorry for the delayed response.
Can I have the pin used on the call.
A quick one, do you have access to the client? if yes can you contact support i want us to make some test.
1. Make a test with a pin
2.see if the pin will appear on raw file.
3.check if plugin translate it correctly.
Regards
Luanda
Luanda_Junzi
