No incoming call information on reports
Postby janet02 » Mon Sep 18, 2017 12:21 pm
Hi Support,
A plugin was created for a client last year but there is no incoming call information when drawing reports. Please find raw data, configuration file & a copy of the report.
The ticket for the original plugin was TNG Alcatel OmniPCXOffice Office Link Driver Service Plugin
janet02
Re: No incoming call information on reports
Postby janet02 » Tue Sep 26, 2017 8:37 am
Morning support, do you have any news on this.
janet02
Postby Odette Danster » Fri Oct 06, 2017 10:32 am
Dear Janet
Thank you for your query.
Unfortunately, the post does not have any attachments. Please upload the raw data, configuration file and copy of the report to this forum post.
Can you also confirm when the issue with the 'no incoming call information' started?
Thanking you in advance.
Kind Regards
Odette
Odette Danster
Postby janet02 » Fri Oct 06, 2017 11:38 am
Hi Odette,
I thought I had attached the raw data etc. let me try again.
The client only recently required incoming call info so I can't confirm for definite if the issue was always there.
Regards
Janet
wetransfer-f5cc83.zip
janet02
Postby janet02 » Mon Oct 16, 2017 10:58 am
Morning Odette,
Can you please give me an update on this? I need to get back to the client urgently as they have been waiting for a long time now.
Regards
Janet
janet02
Postby janet02 » Mon Oct 23, 2017 9:07 am
Good day,
Please can you let me have any update.
janet02
Postby Odette Danster » Thu Oct 26, 2017 10:27 am
Dear Janet
Please accept our sincerest apologies for the delay. I've tried to call you on both numbers (office and cell) and left voice messages.
I've looked at the attached files but could not find the raw/smdr data. Can you please navigate to C:\Program Files (x86)\datatex\tng\logs select the date folder and check if you have a raw.txt file?
If so, please attach the raw.txt file to this forum post. The rawdata can be for any date period, provided that it contains incoming call records.
Kind Regards
Odette
Odette Danster
Postby Odette Danster » Thu Oct 26, 2017 3:59 pm
Dear Janet
As discussed telephonically.
I need the actual smdr/raw data files from the client for us to investigate why the Incoming calls are not reflecting in TNG.
You mentioned that you have data saved on your PC and that I can connect to your PC tomorrow morning around 10am. Please call me with the team viewer access details.
Kind Regards
Odette
Odette Danster
Postby Odette Danster » Wed Nov 01, 2017 2:37 pm
Sent: 01 November 2017 08:31
To: Janet Muller
Subject: RE: {Disarmed} RE: OUP info
Good Morning Janet
There could be a few reasons for this, like if the PABX was updated or changes were made to the configuration or output format of the rawdata might have changed.
The raw data I used for testing was for 2016. I will need more recent call data to investigate the reasons why Incoming calls are not reflecting.
Can you please send data for this month?
Kind Regards
Odette Danster
Support Helpdesk
_________________________________________________
Sent: 31 October 2017 19:11
To: Odette Danster
Subject: Re: {Disarmed} RE: OUP info
Hi Odette,
Why then does none of the incoming information show on reports, ie: show how many incoming calls each extension is taking especially switchboard?
Regards
Janet
To: Janet Muller
Sent: Tuesday, October 31, 2017 5:02:08 PM
Subject: {Disarmed} RE: OUP info
Dear Janet
I used the older rawdata and the plugin does read the Incoming calls. Please see screenshot.
Kind Regards
Odette Danster
Support Helpdesk
Odette Danster
