EAST RAND PLASTICS CONFIG Resend
Postby EAST RAND PLASTIC » Thu Nov 02, 2017 3:22 pm
No 06 prefix costs rates
EAST RAND PLASTIC
Re: EAST RAND PLASTICS CONFIG Resend
Postby Odette Danster » Fri Nov 03, 2017 3:24 pm
Notification:
I called and assisted Godfrey telephonically and by connecting via team viewer.
Once connected I added the prefixes to the all_custom_ratebook name.txt located in the C:\Program Files (x86)\datatex\tng\rates folder.
Odette Danster
Postby Belinda Frick » Fri Nov 10, 2017 3:53 pm
Investigation found that new prefixes was allocated in 06 range for cellular:
0615 CELLC
0616 CELLC
0617 CELLC
0618 CELLC
0619 CELLC
062 CELLC
0630 MTN
0631 MTN
0632 MTN
0633 MTN
0634 MTN
0635 MTN
0636 Vodacom
0637 Vodacom
0640 MTN
0641 CELLC
0642 CELLC
0643 CELLC
0644 CELLC
0645 CELLC
0646 Vodacom
0647 Vodacom
0648 Vodacom
0649 Vodacom
0654 CELLC
0658 TELKOM
0659 TELKOM
0660 Vodacom
0661 Vodacom
0662 Vodacom
0663 Vodacom
0664 Vodacom
0665 Vodacom
The lastest version of TNG rates does not include these prefixes therefore they cost at zero.
To cost these prefixes you need to setup custom rates.
The feature to use is simple custom rates - refer to topic :
TNG - Simple Custom Rate
Follow these instructions to create your custom dll file.
For your convenience I added an example of the simple custom all ini file:
all_custom_simple-Plastics.ini
NOTE: In the example we used costing of R 0.0115 per second. You need to modify this as per your costing rate.
