Centos 6 and TNG
Centos 6 and TNG
Postby Leon van Heerden » Fri Nov 24, 2017 11:03 am
TNG is a 32 bit application and on 64bit servers if requires the 32bit version on the libraries to work.
This should install the libz (32bit) on test.
If you get this message, you need to install the libz 32bit
./tng: error while loading shared libraries: libz.so.1: cannot open shared object file: No such file or directory
yum install zlib.i686
yum install libgcc_s.so.1
