Hi Support,
I scheduled a report to run at 10:00 AM today(20160605), and below is the errors I am getting in the log files, is this something that you can sort out or if you can give me a way on how to resolve it,
Looking forward to your response,
[root@fx-africa ~]# cat /opt/datatex/tng/logs/20190605/tng.log
2019-06-05 01:00:00:472 [1.1.1.13] - [AMI LOG] - CDR File "/var/log/asterisk/cdr-custom/Master.csv" moved to processed.
2019-06-05 01:00:23:518 [1.1.1.13] - [AMI LOG] - CDR File "/var/log/asterisk/cdr-custom/Master.csv" added to list.
2019-06-05 01:02:08:731 [1.1.1.13] - [AMI LOG] - CDR File "/var/log/asterisk/cdr-custom/Master.csv" added to list. [Repeated 2 times]
2019-06-05 01:02:08:731 [1.1.1.13] - [AMI LOG] - CDR File "/var/log/asterisk/cdr-custom/Master.csv" does not exists
2019-06-05 01:52:14:903 [1.1.1.13] - [AMI LOG] - CDR File "/var/log/asterisk/cdr-custom/Master.csv" does not exists [Repeated 50 times]
2019-06-05 02:42:21:155 [1.1.1.13] - [AMI LOG] - CDR File "/var/log/asterisk/cdr-custom/Master.csv" does not exists [Repeated 50 times]
2019-06-05 03:32:27:456 [1.1.1.13] - [AMI LOG] - CDR File "/var/log/asterisk/cdr-custom/Master.csv" does not exists [Repeated 50 times]
2019-06-05 04:22:33:877 [1.1.1.13] - [AMI LOG] - CDR File "/var/log/asterisk/cdr-custom/Master.csv" does not exists [Repeated 50 times]
2019-06-05 09:21:09:343 [1.1.1.13] - [AMI LOG] - CDR File "/var/log/asterisk/cdr-custom/Master.csv" does not exists [Repeated 11 times]
2019-06-05 09:21:09:343 [1.1.1.13] - admin disconnected after timeout
2019-06-05 09:21:16:573 [1.1.1.13] - User admin connected from 196.35.15.7
2019-06-05 09:23:23:639 [1.1.1.13] - admin_DepartmentSummaryUser_20190605092200.rep scheduled to run on Jun 05 at 10:00. Options:|email|
2019-06-05 10:00:01:432 [1.1.1.13] - Need to run scheduled report admin_DepartmentSummaryUser_20190605092200.rep
2019-06-05 10:00:01:433 [1.1.1.13] - Executing scheduled report : admin_DepartmentSummaryUser_20190605092200.rep [|email|]
2019-06-05 10:00:45:440 [1.1.1.13] - Send Email Failed : Socket Error # 111[13][10]Connection refused.
2019-06-05 10:00:45:441 [1.1.1.13] - admin_DepartmentSummaryUser_20190605092200.rep nextrun on Jun 06 at 10:00
2019-06-05 10:14:06:554 [1.1.1.13] - admin disconnected after timeout
2019-06-05 10:14:12:049 [1.1.1.13] - User admin connected from 196.35.15.7
2019-06-05 10:53:21:832 [1.1.1.13] - admin disconnected after timeout
2019-06-05 10:53:21:832 [1.1.1.13] - Owner from IP : 196.35.15.7 got timed out.
2019-06-05 10:53:33:392 [1.1.1.13] - User admin connected from 196.35.15.7
