Unable to access tng shortcuts
Postby refiloe » Fri Aug 16, 2019 3:49 pm
Hi All,
Can you please assist, we have restarted a clients tng, and now the shortcuts or buttons at the top of the site are not working, they have tried accessing tng with different browsers but still get the same results,
Could you please assist with that,
refiloe
Re: Unable to access tng shortcuts
Postby refiloe » Mon Aug 19, 2019 8:53 am
Hi,
Can you please assist with this request
refiloe
Postby refiloe » Mon Aug 19, 2019 12:00 pm
Hi,
Is there anyone to assist with this request
refiloe
Postby Leon van Heerden » Thu Aug 22, 2019 10:10 am
As Discussed.
Checking the logs in /opt/datatex/tng/logs/20190822/
you can use this command to view the log live. (user CTRL + C to stop the tail command. )
tail -f tng.log
Next open the page with Chrome and then open the developer console. (F12) go to the CONSOLE tab and then try and click on the buttons. Those buttons at the top of TNG are driven with JavaScript and if the error is on the browser side, the console will display the error. If the error is on the software side, the tail command will display the error.
Please show the errors here so that we can check the next steps.
