Vadocom custom rate book not costing
Postby charl_itec » Thu Oct 24, 2019 11:52 am
Please see attached is the files. I'm struggling to get the costs correct. It shows the costing as R0
charl_itec
Re: Vadocom custom rate book not costing
Postby Belinda Frick » Fri Oct 25, 2019 9:18 am
Dear Charl
I used the files you provided and just updated my tng.ini file with your section:
[PLUGIN]
localnumber=0515227038
localcode=051
countrycode=27
internationalaccesscode=00
pluginName=PAastra_A470_Format_PC5
pluginPath=C:\Program Files (x86)\datatex\tng\plugins\
defaultratebook=all_custom_simple
swoppinaccount=0
autoupdatenames=1
lograwdata=99999
Branch Code=021
My plugin version is:
I did a rebuild of the exchange file:
How do I re-create the TNG Exchange file?
I re-placed the simple custom rates files in the folder:
C:\Program Files (x86)\Datatex\tng\rates
with:
I imported the raw data and it costed:
NOTE:
Please check that your numbers displays in the same format and outgoing calls with a duration shows a cost.
There must be no rules configured in the rules.ini file in the folder:
C:\Program Files (x86)\Datatex\tng\plugins
Cost Calculator also cost:
