0 striped from incoming transferred number
Postby andre » Mon Jul 20, 2020 9:45 am
20200720.txt
raw.txt
Morning I had an issue with a internal sip trunk where country and area code was in front of ext we added a rule and it seems to work for the extensions but now there is no 0 in front of a number when it is transferred to the call centre from the reception can you please help.
andre
Re: 0 striped from incoming transferred number
Postby Belinda Frick » Wed Jul 22, 2020 9:57 am
Dear Andre
See below an extract from the raw.txt file.
Please note that these are unformatted data strings from the PABX.
You will note that some numbers does not have a leading zero, for example: 745818534
   406                    421 200720 07:35 00H03M09                  02102 745818534        406                                      001 245 7189
You need to configure the PABX to send of the data correct.
I will not be able to assist with PABX configuration, you will need to follow up with PABX service provider.
Extract of raw.txt
                          114 200720 07:35 00H03M24       0.00 00000 02102 0745818534           0745818534           6300                                     6300                                             7188
   331                    010 200720 07:38 00H01M15       0.00 00000 02101 331                                       0722975315                               0722975315                                       7190
   425                    010 200720 07:39 00H00M18       0.00 00000 02101 425                  6425                 0727511601                               0727511601                                       7191
   399                    010 200720 07:39 00H00M55       0.00 00000 02101 399                  6399                 0812772110                               0812772110                                       7192
   407                    421 200720 07:40 00H00M45                  02102 828173298        407                                      005 247 7193
   314                    010 200720 07:40 00H01M40       0.00 00000 02101 314                  6314                 0735552096                               0735552096                                       7194
   534                    010 200720 07:41 00H01M08       0.00 00000 02101 534                                       0722975315                               0722975315                                       7195
   310                    010 200720 07:42 00H00M38       0.00 00000 02101 310                  6310                 0783409846                               0783409846                                       7196
   6300                   321 200720 07:39 00H03M17                  02101 0828173298                                6300                                     6300                                     000 246 7197
