How do I configure the shortcut keys in VIP
Postby Belinda Frick » Thu Dec 02, 2010 11:53 am
Press F4 to open the Opperator Assistant. (That is the default key.)
Now press F1 for the help screen. All system shortcut keys are listed here.
While this screen is open, all keys that are pressed, will display a scan code
at the bottom right corner of the window. That is the code that can be entered
into the configuration file of your VIP to change the keys.
The File:
C:\program files\datatex\vip\vip.ini
[HOTKEYS]
;Once you have the Operator Assistant open, Keypresses will show the Scancode
;that can be used here to configure your own keys.
;Press "Keypad +" to show
SHOWVIP=107
;Press F4 To hide Operator Assistant
SHOWOPAS=115
;Press F3 to Hide
CLOSEALL=109
By changing these numbers the shortcuts are changed.
Added by Hilton
The default keys may be ones you commonly use. I suggest you use:
; Ctrl-Alt-V to show
SHOWVIP=49238
; Ctrl-F12 to hide operator assistant
SHOWOPAS=16507
; Ctrl-F11 to hide current window
CLOSEALL=16506
Return to Emerald
