2010-10-29 09:49:44:846 [1.0.7.0] - Exchange Library : Verifying Versions...
2010-10-29 09:49:44:846 [1.0.7.0] - Error with MD5 : Cannot open file "C:\Program Files (x86)\datatex\tng\exchange.dat". The system cannot find the file specified
2010-10-29 09:49:44:846 [1.0.7.0] - Exchange Library : exchange.dat Changed!!
2010-10-29 09:49:44:846 [1.0.7.0] - Exchange Library : !!Could not get Exchange Handle!!
2010-10-29 09:49:44:846 [1.0.7.0] - C:\Program Files (x86)\datatex\tng\exchange.dat does not Exist!!!
Try the following:
In the folder 'C:\Program Files\datatex\tng\' check that
Windows is set to show file extension (.txt, .dat, .dll, etc.).
Now look for the following files:
exchange.dat
exchange.dll
exchange.txt
If the exchange.dll is missing, you need to check on which
version of TNG you are and then run the update for it to get
the exchange.dll file.
In the folder
C:\Program Files\Datatex\tng\data
check the newest version for the file *data*.dat,
for example 1data_1.0.7.0.dat, then it is version 1.0.7.0.
Once you have the 'exchange.dll', then the 'exchange.dat' file
can be created.
Log into TNG and check if it is now working.
