TNG report: My drill down functionality is disabled
Postby Belinda Frick » Fri Nov 12, 2010 6:06 pm
Please note that TNG will automatically disable further drill down fucntionality if it detects
that the report being processed is too large. The user can either select a shorter date period
to reduce the amount of calls, or use the detailed report options to view the calls for the
previously selected date period.
