- local and national rates
- international rates
Local and national rates:
- The different zones the country uses, example Western Cape (021).
- The different areas with-in the zones, example Erika with the dial-codes in that area.
- How the different rates are charged, for example:
- national (Telkom C - over 100 km)
- between zones (Telkom B - over 50 km)
- with-in zones (Telkom A - local)
- international
- Rates (per units or per second) and time table for peak time and off-peak times.
Example:
peak time : Monday to Friday 07h00 until 20h00
off-peak time: Monday to Friday 20h00 until 07h00
: Friday 20h00 until Monday 07h00
Billing R1.00 per unit
first unit 60 seconds @ R 1.00
second unit 30 seconds @ R 0.50 - The VAT factor for that country, example South-Africa 14%, Botswana 11%.
- Minimum rate, example Telkom R 0.43 (excluding VAT).
- Telephone number system, example 0215924033. In South-Africa we use 10-digit dialing.
021 - zone
592 - area with-in zone (Erica) - Do they use the local area prefix with the local number?
- Please get the following in spreadsheet format so that it can be processed programmatically:
- DialCode Description Rate/Min
- Code: Select all
091918 OKLAHOMA 3.09
- DialCode Description Rate Category
- Code: Select all
021592 BARRACKSTR Telkom A
021939 BARRACKSTR Telkom A
- Rate Category Rate Rate Description
- Code: Select all
Telkom A 0.43 TELKOM RATES LESS THAN 50 KM'S
Telkom B 0.43 TELKOM RATES OVER 50 KM'S
International rates:
- To link the rate to the country, I need the dial codes
for the countries with the description for that country.
example:
Description ,DialPrefix ,Rate- Code: Select all
ALBANIA MOBILE ,935538 ,0.07067
- I also need the peak and off peak times.
example:- peak:
Monday to Friday, 07h00 until 19h00 - off peak:
Friday 19h00 until 24h00
Saturday and Sunday
Monday 00h00 until 07h00
- peak:
- Does the rates supplied include VAT?
- What is the VAT factor for your country?
- Is it per second or per unit billing (and what is the unit)?
example:
Billing R1.00 per unit,
where first unit 60 seconds @ R 1.00,
and second unit 30 seconds @ R 0.50 - Is there a minimum charge for a call, and is it regardless of the duration?
- Is there a maximum charge for a call, and is it regardless of the duration?
- What is the name of your service provider?
example, Telkom, Euram...
