How to get hte TNG buffer to work in Linux
Postby Leon van Heerden » Mon Nov 28, 2011 7:44 pm
The TNG buffer requires the following driver to be loaded:
ftdi_sio
You can set the settings for this driver in the modprobe configuration files.
The ftdi_sio driver requires the following settings to be set in the
/etc/modprobe.conf.d/tng_buffer.conf file. If it doesn't exist, create it.
options ftdi_sio vendor=0x0403 product=0xbda8
Now you can unload the driver and load it again using these commands:
To allow auto loading of the driver on startup, add the driver name to the /etc/modules file.
/etc/modules
ftdi_sio
Unload
/sbin/rmmod ftdi_sio
Load Driver
/sbin/modprobe ftdi_sio
This should create the device /dev/ttyUSB0 or if there is already one, the next device in the list.
Run this to check the last output from the kernel to see which device got loaded.
dmesg
The output should look like this:
[16095.844582] usbcore: registered new interface driver usbserial
[16095.844629] USB Serial support registered for generic
[16095.847218] usbcore: registered new interface driver usbserial_generic
[16095.847225] usbserial: USB Serial Driver core
[16095.865400] USB Serial support registered for FTDI USB Serial Device
[16095.866808] ftdi_sio 5-1:1.0: FTDI USB Serial Device converter detected
[16095.868452] usb 5-1: Detected FT232RL
[16095.868458] usb 5-1: Number of endpoints 2
[16095.868462] usb 5-1: Endpoint 1 MaxPacketSize 64
[16095.868465] usb 5-1: Endpoint 2 MaxPacketSize 64
[16095.868468] usb 5-1: Setting MaxPacketSize 64
[16095.873614] usb 5-1: FTDI USB Serial Device converter now attached to ttyUSB0
[16095.873670] usbcore: registered new interface driver ftdi_sio
[16095.873674] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
You should see a line where the ttyUSB0 was loaded. (if you have other USB devices on the PC, it might not be 1, but some other number)
