My calls are not costing correct. The telephone numbers has a leading 9, which causes the incorrect prefix lookup and therefore costing.
Solution:
To strip the leading 9, you need to use a plugin rule.
You can only fix the historic data, if you logged rawdata.
Steps:
- See forum post to strip a digit for a number:
How do I strip extra digits off the telephone number?
Try to keep what you strip unique, not to modify it incorrectly.
First implement the plugin rule and check that it works correct - refer to Call List page. - NOTE: Please check that you have rawdata files to import before you blank the TNG database. For future use please ensure that log to rawdata is enabled:
How do I enable logging of rawdata? - To blank the historic data from TNG:
- Stop the TNG service
- Windows: START -> CONTROL PANEL -> ADMINISTRATIVE TOOLS -> SERVICES,
click on TNG and then the 'stop' link.
Linux: Stop the deamon - see
How do I stop and start the TNG service on LINUX? - Once the service is stopped, navigate to
- For Windows: C:\Program Files\datatex\tng\data
For Linux: \opt\datatex\tng\data - Create a backup folder, for example the date '20120113'.
- Move the tng '?_data-?' .dat files into the backup folder.
- Start the TNG service.
- Log into TNG.
- You will now have a blank TNG and only calls terminating now will load.
You can verify this on the 'Call List' page, as it shows only the last 50 calls for today and tomorrow.
- To re-import the rawdata files, please refer to forum link below.
How do I import rawdata into TNG?
