How do I install TNG on Linux?
Postby Odette Danster » Mon Jan 23, 2012 12:13 pm
TNG Linux Installation notes:
NB: Login as the root user to do the installation.
To install the rpm type "rpm -i rpmfilename" and press enter.
If it complains about File Dependencies run "rpm -i --nodeps rpmfilename".
It will install to the /opt/datatex/tng folder.
Once the RPM is installed type "/opt/datatex/tng/tnglinuxinstaller" and press enter.
Follow the onscreen instructions.
When complete, the system will automatically try to start the TNG daemon and you should be able to access TNG with http://tngpcname:7080. An onscreen message will display the correct pc name.
The default username is "admin" and password "datatex".
Odette Danster
