TES: can I delete an user?
Postby Belinda Frick » Wed Feb 01, 2012 11:37 am
You can delete an user, but note that this will delete the entire history of this user from TES only.
All history in TNG for this user will stay as is. TES does not have access to TNG to modify anything.
You have to be Level 8 and then you can remove a user as follow:
  • Login with your Level 8 login.
  • Click User Settings at the top of the page.
  • Click "Delete Users" on the Administration page.
  • Tick the username that you want to delete.
  • Click Apply at the bottom of the page.
You can scroll through the pages using the next page icon at the bottom right of the page.
PLEASE NOTE: the entire call history for this user will be removed.
