Where do I find the TNG for COMX(Far South) install?
Postby Belinda Frick » Tue Feb 14, 2012 2:34 pm
NOTE: This is a debian install:
tng-1.0.7.7-1_all.deb
To install make sure you are sudo.
sudo -s -H
sudo dpkg -i  tng-1.0.7.7-1_all.deb
NOTE: This install will work on Far South COMX and Asterisk. The install will check if it is a Far South box and install the COMX version, else the standard TNG for Asterisk.
NOTE: TNG for Asterisk has a 30 day trail period. If you load call details older than 30 days TNG will expire.
Re: Where do I find the TNG for COMX(Far South) install?
Postby Belinda Frick » Fri Apr 25, 2014 1:16 pm
For latest version of TNG for Asterisk (as of 2014-04-25) refer to
download 'tnglive-update-1_1_1_12' in the 'Updates' section
in forum post: TNG Update 1.1.1.12
NOTE: This will update your TNG for Asterisk to the Live version, you must connect via the internet to activate your TNG for Asterisk - else it will run in TNGLive Free mode.
