My extension list is blank
Postby Belinda Frick » Fri Mar 02, 2012 10:12 am
I configured all my extensions, when I go to Extension configuration it list no extensions numbers only the icon to delete the entries, see screenshot
It looks like the extension file is corrupted. Because of the file corruption you will need to blank the file and add/import the extensions again. Please see forum post: How do I import extensions from a file into TNG?
Re: My extension list is blank
Postby Belinda Frick » Fri Jun 29, 2018 8:15 am
This has also been noted after a power out, that no extensions displayed under extension configuration.
Power failure can also corrupt the tngext.dat and tngdept.dat files.
Follow the steps : How do I import extensions from a file into TNG?
