Panasonic TEA308: not all my calls are loaded in TNG
Postby Belinda Frick » Thu Mar 15, 2012 9:20 am
We need to see the call details TNG receives and why it does not translate all call data.
Enable logging of rawdata, see forum post:
How do I enable logging of rawdata?
Example of rawdata:
000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
3/13/12   9:49AM 102  03 0824524973                            00:02'44" 0112
microBuffer Rev 1.08
Startup
Total memory fitted =    32768       0       0
PC baud rate =  9600
PABX baud rate =  4800
Beeper  disabled
Seven bit only logging disabled
PC baud rate =  9600
Auto Dump on DTR disabled
Auto Dump delay = 20 * 50 milliseconds
Convert to Upper Case disabled
Sequence number storing disabled
STX = FF
ETX = FF
Store multiple linefeeds disabled
000000000000000000000000000000000000000000000000000000'32" 5645
3/13/12   9:59AM 101  03 1026                                  00:00'04" 5645
00000000000000000000000000000000000000 0828233630                            00:00'31" 5645
3/13/12  10:02AM 101  03 0543375556                            00:00'39" 5645
00000000000000 10:04AM 101  03 1026                                  00:00'40" 5645
3/13/12  10:07AM 101  03 0861114351                            00:05'36" 5645
0000000000000000000000000000000000000000000000                                 00:00'24" 5645
3/13/12  10:40AM 101  03 1026                                  00:00'29" 5645
0000000000000000000000000000001  03 0543375556                            00:00'34" 5645
3/13/12  10:42AM 101  03 0828233630                            00:00'25" 5645
00000013/12  10:43AM 101  01 0722679302                            00:00'20" 5645
000000000000000000000000000000000000000000000000000000000016" 5645
3/13/12  10:45AM 101  03 0800375375                            00:00'16" 5645
NOTE: The data seems shifted due to zeroes.
Corrected output format:
Date     Time    Ext CO        Dial Number        Ring Duration  Acc code  CD
05/07/04 11:38AM *2241 04 6244587                        00:01'39 523
14/07/05 10:26     143 32 0724477653                      00:01'39 5302
14/07/05 10:27     300 21 <I>                                                RC
14/07/05 10:27     500 21 <I>                        0'06 00:00'00
14/07/05 10:27     138 31 0722241321                      00:05'52 0722
05/07/04 11:38AM   233 03 0406779935-C                   00:04'07            TR
27/07/04 04:16PM  *195 04 0860111055322D                 00:03'39
27/07/04 04:16PM   101 01 <I>                       0'03 00:00'15
The format of the rawdata is thus not the standard. You need to check why this is happening. If you disconnect the serial cable from the buffer and connect it straight to a PC, use putty to log rawdata and see if still scrambled. If the TNG PC does not have a serial port, use another PC for example a laptop or a USB2Serial converter.
See forum post : How do I enable logging of data in Putty?. You can download putty from the internet.
  1. If rawdata still scrambled, the problem is between the PABX and the PC. Check the following posts:
    What causes scrambled data?
    What are the pinlayouts for the Panasonic KX-TEA308?
  2. If not scrambled, the problem is between the buffer and the PC. Try the following post:
    How do I reset the TNG buffer?
