Can TNG do barring on the NEC SL1000?
Postby Belinda Frick » Fri Mar 30, 2012 9:30 am
*** Currently there is no TNG barring solution in place for the NEC SL1000. ***
Also see: Which plugin do I use for the NEC SL1000
For current list of barring solutions in place for TNG, click link below:
On which PABX units can TNG do barring?
Re: Can TNG do barring on the NEC SL1000?
Postby Belinda Frick » Fri Nov 23, 2012 12:53 pm
Barring on the NEC SL1000 is now available.
First install your TNG. It must be receiving call details. Configure your extensions or user names in TNG. This will be auto updated to TNGCallbarring where you need to configure the budgets per extension or user.
Download and unrar:
  1. TNGCallbarring:
    • TNGCallbarring install files:
      tng-callbarring-install-1_0_1_23.rar
    • TNGCallbarrring manual:
      TNG CallBarring Installation Manual.rar
  2. NEC SL1000 Callbarring:
    • NEC SL1000 Call barring install files:
      tng-NECSL1000Barring-install-1_0_0_2.rar
    • NEC SL1000 Call barring installation instructions:
      TNG NEC SL1000 Barring Service.rar
Postby Belinda Frick » Thu May 23, 2013 2:10 pm
The barring service install/update:
tng-NECSL1000Barring-install-1_0_1_0.rar
Password is "datatex", without the quotes.
The configuration is exactly the same as the previous version (1.0.0.2) of the SL1000 barring service,
only the communication with the PABX has changed.
NOTE:
This new NEC SL1000 Call barring version does not work with the 1.5 version of the SL1000 PABX. It is for use with version 2.
