by John Richard Procter » Mon Apr 02, 2012 3:33 pm
- Log into the buffers web interface that is on port 80 (standard browser port).
The default IP address is 192.168.0.226.
- Once logged in select the global tab.
In the global tab you are able to configure the IP address in the IP range of the PABX.
The Function must be set as stand alone.
- Once complete with this step select the socket 0 tab.
- In the socket 0 we will configure the Remote PORT NO. and IP address of the PABX
The mode to select is Active.
- Once complete with the configurations select the save tab.
- Once complete please connect your serial cable MALE to MALE to the one end of the cable in PORT 0 on the serial lan adaptor and the other end into the TNG buffer.
